Page 1 of 2 12 LastLast
Results 1 to 25 of 27
Thread: VX using leaded fuel
    ahmedomnnea is offline Ahmed.Iraq
    VX-II Excutive, 3.8 V6/A4
    May 2009
    Iraq
    Question VX using leaded fuel
    Hi,
    I have a 2002 VX with 3.8L V6 engine, Auto trans, All stock (no mods at all).
    the only fuel we have in iraq is leaded fuel, my qustion is:
    what parts in my car that using leaded fuel can hurt?
    I already have a low gas mileage problem, the best I can get is 20L/100Kms.
    the car seems to Idle rough and probabily because the fuel isn't good it has advanced timing and lots of engine knocking especially when the A/C is on.
    checked the O2 sensors and their readings seems right (arround 600 mv), new fuel pump/filter, new air/oil filter, new spark plugs, cleaned MAF and IAC and throttle body, checked the coil packs and seems working fine (spark moves from one to the other),checked for vacume leaks and everything looks fine.
    is using leaded fuel can cause all these problems?
    and one last Q:
    could a cloged cat converter cause rough idle and poor fuel economy?
    any help will be realy appreciated.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Leaded fuel is bad for an unleaded car, it will normally destroy the cat-converter, and cause it to clog. As for engine knocking it is probably because the fuel is too lower octane and the engine is not designed to run on it, but engine knock should be eliminated if the knock sensor is working as it retards the timing when it detects a knock. I'm not sure what exactly the lead in the petrol will do to other parts of the engine and fuel system but i would imagine it cant be good for pumps, seals ect. But i highly doubt it would effect major components like the pistons valves & seats as it was originally in the fuel to lubricate the valve seats anyways.
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Leaded fuel will kill the catalytic converter and that in turn will cause rough idle and misfiring as well as poor fuel economy.
    Silver Certified.
    delcowizzid's Avatar
    delcowizzid is online now on holiday
    в∞ѕтεכ √&
    Jul 2008
    NZ
    o2 sensor and cat is all it will damage.normally the overseas leaded cars dont have cat and o2 sensors
    May 2009
    Iraq
    thanks guys for the quick replys,
    overseas cars do have O2 sensors and cat.
    I will take it tomorrow to a mechanic to check the cat converter, if cloged I will remove it alltogether and replace it with a pipe !!!!, we don't have environment and polution regulations in Iraq.
    VX Evecutive wagon
    Jun 2010
    Alexandra Hills
    all the lead does in fuel is lubricates the valve seats, this is why to change a leaded motor to unleaded you need hardened valves, also the leaded fuel was acuatly higher octain then the regular fuel we get in Australia, so chuck out the cat and it should be a little better
    vr1uz-fe is offline Banned
    vr berlina
    Aug 2010
    australia
    yes leaded dose have a higher octane and is better for the engine in fact if i could i would run leadded in my car but we do have those enviromental laws here so we have to run cats
    but a mate is part of a new hydorgen tec for older cars and sells the kits for 3500 so im gona rangle one of those for my beast
    00 SS M6/79 chev Monza
    Mar 2005
    Quote Originally Posted by delcowizzid View Post
    i have seen some of the saudi cars (in fact i drove one in sydney ...........no cats on the ones we looked at either
    в∞ѕтεכ √&
    Jul 2008
    NZ
    ive been trying to get a copy of the saudi tune for ages and ages
    May 2009
    Iraq
    whats so special about saudi tune?
    May 2009
    Iraq
    Quote Originally Posted by ausrs View Post
    well mine has a cat.
    в∞ѕтεכ √&
    Jul 2008
    NZ
    the saudi cars have no cat no o2 sensor and are setup with open loop fueling im interested in checking it out is all.if you are running leaded fuel you want that tune no cat and no o2 sensor lead kills o2 sensors and cats pretty quickly.
    May 2009
    Iraq
    thanks for the quick reply,
    but my VX has a cat and O2 sensors, and it has very crappy fuel economy (25L/100Km), do you recomond that I remove the cat and O2 sensors for better fuel economy?
    в∞ѕтεכ √&
    Jul 2008
    NZ
    your cat is probably meted or contaminated badly and the o2 sensor is probably reading real slow and/or wrong voltages which will suck gas .you cant run without the o2 sensor on and o2 sensor tune so you will have to fit a new one and just fit them more regularily than normal
  15. #15
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    You cant exactly remove the 02 sensors, if its got them then its tuned to run with them so removal will just put the check engine light on and cause it to run rough and probably go into limp home mode.
  16. #16
    May 2009
    Iraq
    Quote Originally Posted by VK SL 202 View Post
    thats the thing,
    when I disconnect the O2 sensors it doesn't come up with the check engine light !!!, but it comes up when disconnecting the MAF or MAP or TPS.
  17. #17
    в∞ѕтεכ √&
    Jul 2008
    NZ
    did you drive it with it dissconnected
  18. #18
    May 2009
    Iraq
  19. #19
    в∞ѕтεכ √&
    Jul 2008
    NZ
    sure it was the o2 sensor you unplugged LOL there is 2 one on each side exhaust manifold
  20. #20
    May 2009
    Iraq
    I know there is two of them, and I unplugged both of them with no difference in power, fuel economy and feel, its the same and with no check engine light !!!
    then I've cleaned them and plugged them back again but still the same.
  21. #21
    в∞ѕтεכ √&
    Jul 2008
    NZ
    strange maybe it has the leaded tune but has o2 sensors in it for some silly reason does it only have 2 sensors or 4 some of the vx had before and after cat sensors.ide loose the cat for a start
  22. #22
    May 2009
    Iraq
  23. #23
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    We have four wires on our o2 sensors. The extra wires are for the heater circuit in the sensor so it works quicker. I would take the cat off or smash the guts out of it to stop the rough running and pinging. I dont think you can clean the lead off your o2 sensors, they are normally a throw away item and will make your car drink fuel when they are faulty. A dirty fuel filter will also give you bad fuel economy.
  24. #24
    May 2009
    Iraq
    but why no check engine light when I disconnect the O2 sensors? if they are the key to optimum fuel consumption, should I be getting a check engine light on when they are disconnected?
    I chande fuel/oil filters regularily, new fuel pump, so I guess I have no problem there.
  25. #25
    vx
    Jan 2010
    Default fuels
    Did a fuel run on E10,91 95.city run E10 -13.5 l/100k
    91 - 11.5
    95 - 11.5
    and h/way 91- 8.9l/100k..price of fuel E10 $1.14 L
    91 $1.18 L
    95 $1.26 L
    so value for money is 91 unleaded.
  1. leaded or unleaded?... v8
    By joshie1985 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 14-09-2009, 07:10 PM
  2. cracking open fuel tank to change fuel pump?!
    By VS5spdV6uteowner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2009, 08:00 AM
  3. fuel surge turning right? weird inst fuel readings
    By vkotis in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-10-2006, 12:00 PM
  4. Leaded Petrol Replacement
    By kurtbarker in forum General
    Last Post: 11-06-2005, 12:36 AM
  5. To be (leaded) or not to be?
    By Dogmeat in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-05-2005, 03:36 PM
