Results 1 to 11 of 11
Thread: car over heats when 2nd fan turns on
    VX Executive V6
    Jan 2010
    Exclamation car over heats when 2nd fan turns on
    hey everyone just wondering if anyone has had the same prob, i believe this is the case as when i hear the fam turn on my temp goes up once off again car returns to normal temp any ideas cheers
    Raremetal's Avatar
    Raremetal is offline Best of both worlds.
    Series 2 94 VR Wagon
    Jul 2010
    NSW
    Quote Originally Posted by jbangr View Post
    Generally when you hear that sound, unless your towing a big load or giving it a mother load full up a hill/tight twisties you have a problem. Coolant leak/radiator has shit it self, many things can be causing it. Get it tested at your local garage.
    Current ride: 94 VR Commodore Wagon, Series 1 engine in a Series 2 body.
    Wheels: VE SS 19's custom machined to fit VR.
    Sound: Kenwood + matching speakers.
    VX Executive V6
    Jan 2010
    but thats the thing its had a new radiator waTER PUMP AND THERMO FLUSHED asweell (soz bout caps) and yeah all done within the past 2 months
    supercharged vt II acclaim
    Sep 2009
    goldcoast
    may be ya heads leaking, heater tap leaking?.. the machanics can test the water to see if it has exhaust gas's in the water from leaky head..
    but the second fan will come on when its overheating, it wont cause it to overheat..
    Quote Originally Posted by chargedvx6 View Post
    I meant what I said and said what I meant so if you mean to say I said what you think I meant and it wasn't actually what I meant then that means you mistook what I originally said and meant to be wrong when in fact it isn't..
    my supercharged vt acclaim
    http://forums.justcommodores.com.au/...claim-l67.html
    VX Executive V6
    Jan 2010
    awk so what i just go to a macanics and ask them to check if i have a leaking head?
    VX Evecutive wagon
    Jun 2010
    Alexandra Hills
    if the temp is goin up once the fan comes on i would check it is spinning in the right direction, you might have one going the wrong way....
    VX Executive V6
    Jan 2010
    rofl does this happen alot? but also should your collant/water be visable if you were to pull the cap offf, cuz i did so and i couldnt see any and we filled it up with 50/50 anit freeze collant and letes just say took a good 10 secs to fill up? my coolant is leaking maybe?
    Sep 2009
    goldcoast
    yes ya water should be visable, but when its overheating and full of water it will make all the water spew out ya radiator cap into overflow bottle so might not hav a leak.....
    also check ya cap, the seal could be stuffed and letting water out cap into overflow bottle then running out of water and overheating,
    my 3month old cap gave way a few weeks ago , lost $30 worth of 1day old coolant, the bitch, ..
    VX Executive V6
    Jan 2010
    is there a way to test the cap or would you just have to go buy a new one?
    Sep 2009
    goldcoast
    sorta, ya could try filling it up and put cap on normal ,
    pull the hose off the side of the radiator cap.(overflow)
    let it run/idle till get's up to normal operating temp..
    and see if any waters being spat out that pipe ya took the hose off from(side of radiator cap)
    it should only let water out if its way too hot...
    also if you havent already- you have to bleed the water system after its been pretty low on water or can cause air locks and overheating/damage...
    VX Executive V6
    Jan 2010
    shit man i think ill just leave it to the macanics cuz ive been to this other guy and i seriously think he has no idea just atken me for a ride so gunna try a new one but does anyone know of any good place S.E suburbs of melbourne cheers jay
  1. Sub amp turns off?
    By Ray De Man in forum Car Audio
    Last Post: 05-05-2010, 09:29 PM
  2. car turns off?
    By msina1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-05-2009, 06:43 PM
  3. car turns off
    By BOXTROT in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-10-2007, 01:15 PM
  4. air con / fan cant go to 4 (turns off)
    By DJ_TAS in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-01-2007, 06:15 AM
  5. exhaust sounds better when engine heats up????
    By vks in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-11-2006, 07:12 PM
