Results 1 to 11 of 11
Thread: door stuck
    vl wagon
    Jul 2009
    Default door stuck
    hi all,yes my door is locked shut,drivers side rear its not getting power we think (makes no noise when unlocking) wondering if anyone has any ideas how i can get it open ,thought about disconnecting battery and hopeing it willreset itself all ideas would be great thanks oh yeah vx equipe wagon power windows still work
    VT S2 LS1 -VX S2 SS LS1
    Feb 2010
    IPSWICH
    same question was asked yesterday dude. have a look through the posts & how to's. here a link to my how to solve you problem
    VX deadlock stuck on rear passenger door
    vl wagon
    Jul 2009
    Feb 2010
    IPSWICH
    Quote Originally Posted by v8vlwags View Post
    sweet will try that tomorrow thanks any reason why this happens
    Usually the door actuator(electric lock/unlock mech in door) buggers up. they arent made forever unfortunately,lol
    vl wagon
    Jul 2009
    Feb 2010
    IPSWICH
    so i should get a new actuator aswell,to play it safe
    just pull it apart first & have a looky then go from there
    vl wagon
    Jul 2009
    thanks for your help,appreciate it what should i be looking for,and after i take off the metal strip hows the best to unlock the door
    Feb 2010
    IPSWICH
    ok,when you take the strip off,if you look down inside your door you will see a black plastic object with a plug going into it,thats the lock actuator. in front of that towards the rear of the door is your door lock mech.there will be a little plastic rod coming out of the actuator,this locks & unlocks the door. if you disengage this rod from your door lock mechanism( the door lock mech will have levers attached to it that open/close & lock/unlock the door). with the rod disengaged you will be able to unlock the door manually. sometimes you can get away with not doing this & just hook the lock/unlock lever then bobs your uncle,open sesame. this is a basic how to,unfortunately i find some things easier to do than explain unless its sitting in front of me,lol. but this should be enough for you to get the gist of it & know what to look for
    vl wagon
    Jul 2009
    vl wagon
    Jul 2009
    all unlocked now wd 40 the actuator and electrical contact sprayed the plug seems to be working now fingers crossed a special thanks to vtls1 for his help
    Feb 2010
    IPSWICH
    not a worry at all dude,glad i could help
  1. Drivers Door Stuck!
    By [ASLYVY] in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 16-05-2010, 12:20 PM
  2. Door Stuck Locked
    By Pookie in forum VE Holden Commodore (2006 - ?)
    Last Post: 01-05-2010, 05:58 PM
  3. stuck door vb
    By spaazz in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-03-2008, 01:13 PM
  4. door stuck
    By wagonb0y in forum VL Holden Commodore (1986 - 1988)
    Last Post: 12-04-2007, 07:38 PM
  5. stuck door
    By Bush VB in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 27-08-2005, 08:57 PM
