heya guys. im having troubles with my 2000 vt acclaim. while im driving i feel vibrations through the floor and a dull thudding noise comming from the rear wheels. as i keep driving it turns into an extremely loud clicking noise the same as a front wheel cv joint would make if it were shot. it can be heard up to 4 cars away.
ive taken it to my mechanic and he has greased up my rear cv's on both sides but it hasnt stopped it. it hasnt clicked loudly for a few days but it still gives out the vibrations and the thudding noise. ive stopped driving it as of today but noone can seem to tell me what the problem is or could be.
Can anyone please suggest some things i could check or do to recitfy this.
Thanks heaps.
Just thought I'd let you know that I'm going to take a chance and just replace the whole shaft and prey to the heavens that fixes it haha
May have more than one problem, how is the centre bearing?
You mean inthe diff? I haven't checked that as yet but there's no wining noises. I did check my wheel bearing and that's fine.
I think VR38 means the center bearing in the tailshaft?
i had similar probs with my vx, when you gave it some it would thud and vibrate like crazy and turned out to be the centre bearing in the tail shaft, i picked up a second hand tail shaft from a vz from the wreckers for 80bucks and havent had a problem since
you cant just grease up cv joints they need to be replaced if worn as the case harding is ####ed
and the center bearing is probaly ####ed too
Interesting. I must check the bearing then. Is there a way ti check it without taking it apart? I'm kinda new to the mechanical scene.
no if it makes noise and you know it's comming from it then it's ####ed
if your drive shafts are making nosie then there ####ed
if your diff is making nosie it's ####ed
It's an intermittent noise it's not always there but I just jacked it up and spun the wheel again and there is a noise that sounds somewhat like a wheel bearing scraping coming from the tailshaft but it's only a slight noise. I've never noticed that before but saying that I've never really listened for it.
jack it up turn the engine on put it in drive and no acell then listen dont get under it
Ok I'll try that. Thanks for your help. I'll let u know
Ok so I've done the checks whilst being jacked up and there was no unusual noises coming from anywhere, and surprise surprise, as usual when you go to check something, it didn't Do it on the test drive either. So I guess I'll just have to swap out the driveshaft and hope for the best.
Thank you all for your help and responses. I appreciate it. I'll let you all know how it goes.
I had a load cracking noise coming from the rear end, as soon as it went to holden under warranty it stopped.
Lucky i had checked prior to sending it in it was the rear passenger side drive shaft coming from the diff, i could move the shaft up and down.
New shaft, problem fixed
Ok so after a late night, and a stripped bolt, and many trips to bunnings, we got the driveshaft out, I
Going to take it for a run today and see if that fixed the problem. Thankyou all again for your help.
My 2000 vt does the same thing when turning right and when more weight is in the car, it gets louder.
I will be intrested in what you do to fix your car noise, as mine sounds identical.
how did you go with the new tailshaft??? did it fix your problem???
