Any ideas. thanks, ps its ####ing annoying. ps don't hear it much with passengers on the left side. but driving alone it can get loud as hell. its stops when i brake.
comes from the outside., aircon on or off still there. im thinking its a sticking caliper, but not 100%
easy way to see whats what. with someone inside the car to operate the brake pedal,jack the front of your car up. once done first check for play in your wheel(hold top & bottom of wheel then wiggle,do the same with the left & right of the wheel) if play is excessive you have a bearing issue. when you have done that spin the wheel as fast as you can by hand,check for noise. then get person in car to apply brakes slowly & see what happens.
