Results 1 to 10 of 10
Thread: new vt fuel pump fitted: car almost stalls?
    99 VT Commodore
    Mar 2010
    south east queensland
    Default new vt fuel pump fitted: car almost stalls?
    so i replaced the fuel pump in my vt (ecotech V6) it struggled to idle properly for a minute then come good, so i took it for a test drive and it was smooth until i put my foot down and the engine almost stalls but then comes good!!!??
    i cant get my head around it, its a brand new pump fitted exactly the way the old factory one was. could it be that the tank was low on fuel? ive put 15litres in and it hasnt happend - yet. im not to familar with commodores, still learning bout em. and it only happends at low revs changing gears from 1st to 2nd (auto box)...
    thoughts? thanks for any help cheers
    AUII XR8 Ute & BAII XR6
    Dec 2008
    Brisbane, QLD
    Sounds like a fuel flow issue, maybe the new fuel pump sits a little higher in the tank hence not being able to pickup the fuel too well; when you put the fuel down, the fuel rushes to the back of the tank and away from the pickup.
    151 Countries, One Cúl-Báire!
    Cúl is a regretted trademark of the Cúl-Báire Co-op Pty Ltd, as are his random ramblings and associated bullsh1t
    Cúl's AUII XR8 Ute!!!... Clicky Clicky!
    99 VT Commodore
    Mar 2010
    i see what you mean. just took it for a drive with more fuel in it and yeah it hasnt happend =) i'd say your right with it not having enough fuel flow when the fuel is to low.
    KrystallyVT's Avatar
    KrystallyVT is offline Local Badass.
    VX '02 Acclaim Series 2
    May 2010
    Canberra, ACT
    I don't know if you got it fixed yet, but mine had the same problem.
    Becomes hard to start, and if you turn right on a round about it stalls too?
    Getting a whole new fuel pump kit put in it because the wires and what not were pretty dirty apparently.
    So I'm hoping that's all it is.
    Goodluck with it mate, this problem had been doing my head in for months!
    99 VT Commodore
    Mar 2010
    nah havnt had it fixed yet aye, ive pulled the tank out n everything - pulled the pump out again n placed it in the assembly n back in the tank the way i got it out and its still playin up!!! gonna get a new tank, pump and assembly n get it fitted up...hopefully thats the end of the problem. its really annoying stalling on a right turn with still just under a quarter of a tank left..
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    Check the age of the fuel-line filter. It's most probably full of 'crud'. If you did replace it at the same time as the new pump (which you should have), did you install it with the arrow facing in the correct direction?
    99 VT Commodore
    Mar 2010
    sh*t!!! nah i didnt even think to replace that! i'll get one this week n replace old filter n see how it goes....should of known better but i just forgot..
    vs vacatioer
    Dec 2010
    perth
    i have the same problem but mine is a vx turn right and the car cuts out i have replaced the fuel pump and fitters plz help its driving me isane
    May 2004
    Try cleaning your MAF. I had the same problem and it turned out to be a dirty MAF sensor.
    vt executive sedan
    Dec 2011
    Wagga Wagga
    Most likely fuel hoses loose or 'o' ring disloged causing it to suck air. recheck fitment.
  1. have had to wack the fuel tank to start my car!! is my fuel pump stuffed?
    By CV6Z in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-08-2010, 04:13 PM
  2. [SA] VL 6cyl FUEL PUMP - NEW - never fitted
    By woteva in forum Parts And Other Items For Sale
    Last Post: 20-02-2010, 02:24 PM
  3. vn on gas fuel stalls
    By buddz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-06-2009, 05:19 PM
  4. Car starts but stalls - fuel pump?
    By MasterOfReality in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-10-2007, 08:52 AM
