Results 1 to 21 of 21
Thread: VT SS (5L) Fuel
    Still Searching!
    Jul 2009
    Default VT SS (5L) Fuel
    Just a quick one, can the 5L vt ss run on regular unleaded petrol, or does it need premium unleaded?
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Not sure, should say in your owner's handbook. I run my V6 on premium all the time for cleaner injectors, engine and slightly better economy/power. Only makes a difference of $3-$4 per tank.
    Still Searching!
    Jul 2009
    i havent got one yet lol, just doing a bit of research because ive found one im pretty keen on
    2010 Isuzu FXZ 1500 on 20's
    Oct 2006
    Bogan enclave
    Will run fine on regular but I'd be suss of ethanol. Might pay to run it on 95 instead. My Golf state 91 is fine but I run it on 95 minimum. The SS is tuned for 98 so it only gets that. But before the mods I ran this on 91.
    VT SS
    Oct 2009
    shepparton, victoria
    AUII XR8 Ute & BAII XR6
    Dec 2008
    Brisbane, QLD
    It will run fine on regular, just steer clear of E10...
    No real benifit of running it on 95 or 98 unless it's been tuned for it!
    151 Countries, One Cúl-Báire!
    Cúl is a regretted trademark of the Cúl-Báire Co-op Pty Ltd, as are his random ramblings and associated bullsh1t
    Cúl's AUII XR8 Ute!!!... Clicky Clicky!
    Still Searching!
    Jul 2009
    ok cheers!
    now to do some calculations to see how i can afford running it D:
    VT 1997 SS
    Aug 2010
    Gold Coast
    VYMAD's Avatar
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Quote Originally Posted by mucv8 View Post
    Any ideas of the results of running on e10??
    Many say yay, many say nay. I am dead against using that shit, have seen occurrences on TV shows and eyewitnesses where that shit has stuffed up components. The car manufacturers say "Yeah, no worries use E10" Car will run fine on it for the warranty period, but seriously if things stuff up after the warranty has expired, then that's good news for them- can charge you craploads to fix damaged components, telling you stuff like"You must have had dirty fuel,etc, etc" Many members will dispute this as they swear by the stuff, personally I reckon that's thier prob. I'm never putting it in my car. Anyway, come next year the two choices will be E10 or premium.
    VXII
    Nov 2009
    E10 is fine for just about any unmodified car in Australia. It has a higher octane rating than regular 91 (E10 measures around 94 or 95 RON depending on brand). Adding ethanol (alcohol) to your fuel will help remove the water in your tank (yes, all tenks get it). People fall too much for the marketing dribble of premium fuel.
    VXII
    Nov 2009
    ...and people that believe those evening TV 'entertainment' shows deserve to be ripped off.
    VYMAD's Avatar
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Quote Originally Posted by moose man View Post
    What's your problem? This was a fairdinkum occurrence where the bloke took the car to a mechanic and after stripping everything down, somehow the mechanic was able to prove that E10 had stuffed the engine. Went to court and the bloke won. But why should I waste my time explaining myself... just run ya car on E10 mate!!!
    VYMAD's Avatar
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Oh, to the OP, I would strongly advise you to read through "The E10 Debate" in the Pub forum, there are three pages of posts and a link to tests that were carried out on the stuff. Then you can make up your own mind.
    VXII
    Nov 2009
    Quote Originally Posted by VYMAD View Post
    ...somehow the mechanic was able to prove that E10 had stuffed the engine...
    'somehow'?
    You don't even know yourself, yet you trust a TV host entertainer to tell you it is true?
    Sample size = 1 (a very unscientific 1)
    Conclusion: E10 must be bad!
  15. #15
    VT V8 Calais
    Mar 2007
    I use E10 in my 5 liter and have used in a ford 6 previously, no issues at all.
    50LTRv8
  16. #16
    VYMAD's Avatar
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Just wait a couple of years, til you start replacing injector rubbers, valve seals your car-your choice.
  17. #17
    VYMAD's Avatar
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    'somehow'?
    Yes, "somehow",it was a couple of years ago I saw the show, and I remember that after stripping the engine down, the mechanic's verdict was that E10 was responsible for the damage. I am not a mechanic and I can't tell you which part/s of the engine were stuffed. Eh, maybe you are right, just TV bullshit, eh? LOL I still won't put the shit in my car..........................
  18. #18
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Same man, will never use it in the vs and deff not in the ve, ill stick with the 98
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
  19. #19
    VT V8 Calais
    Mar 2007
    I have been running it on E10 for 4 years, so when should I expect it to break then?
    50LTRv8
  20. #20
    VXII
    Nov 2009
    Unfortunately the odds of that happening are stacking against you. Millions of Aussies have happily used it for years with only the odd account of engine problems, which we already know about. I'd say that if engine/component failure was as common as is stated in this forum, E10 would have been removed from sale long ago and oil companies would have huge court cases to answer to.
    I could be wrong, and in 30 years we find that E10 has caused all sorts of problems with cars. If that proves to be the case, I'll eat my words.
    (To be honest, I don't reckon we'll even have liquid-fuel powered cars in 30 years, but that's a different topic.)
  21. #21
    VT S1 SS 5.0 5 Speed
    Nov 2009
    i do not know about the E10 however, i have a 5.0 VT SS Manual. i have used all of the Premiums (BP, MOBIL and SHELL) i found Mobil to be the best.
    my car is 98 % stock and i can notice a HUGE difference between regular and premium. the best example i can give is this, on my regular drive to work from Narre Warren to Clayton (Victoria around 30 KM each way ) my average fuel was 10.7 l/100k using Mobil SYNERGY, the absolute best i got from BP and SHELL was 11.4 l/100k. then on regular it was around 13 l/100k (on a good week) it all ads up to about 60kms per tank.
    I simply ran my car for 6 weeks using ULP, then 6 weeks using PULP from BP, then the same from Mobil etc, so i had some very solid data to support my results.
    i believe the extra $8 a tank is definitely worth it, besides i can get 9.6l/100k on my drive from Melbourne to Newcastle doing 120kls/hr on PULP but only get 10.6 with 95 PULP! i would hate to see what ULP would do.
    This is just my opinion, and my Wifes, and my cousins, and my good mates....... i could go on.
    believe what you will but you can't ignore the facts!!
  1. blockage in fuel line - appears to be fuel pressure regulator??
    By ryan1980 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-08-2011, 06:23 PM
  2. have had to wack the fuel tank to start my car!! is my fuel pump stuffed?
    By CV6Z in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-08-2010, 04:13 PM
  3. cracking open fuel tank to change fuel pump?!
    By VS5spdV6uteowner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2009, 08:00 AM
  4. fuel surge turning right? weird inst fuel readings
    By vkotis in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-10-2006, 12:00 PM
  5. fuel injected 5ltr motor setup for dual fuel
    By ma77es in forum Swap / Wanted to Buy / Trade
    Last Post: 28-05-2006, 07:03 PM
