Results 1 to 14 of 14
Thread: unusual rattle
    98 VT Executive
    Aug 2008
    Sunshine Coast
    Default unusual rattle
    Hey Guys,
    my car has an unusual rattling noise when idling that is pretty in sync with the shaking of the engine.
    my mechanic told me that the two things that the engine sits on have worn down heaps and that i should get new ones. I stupidly forget what they're called...engine mounts...or something?
    He said it's like thick rubber or something.
    If this is making sense, do you think that would be causing the rattling noise. It gets pretty loud when i just start the engine and is loud inside the car.
    Please let me know,
    cheers!
    Joe
    Joe
    [url]www.cleangetaway.com.au[/url[
    Your Professional Car Detailer
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    Sagged engine mounts are very common. The sump hits the front crossmember when the mounts get bad.
    98 VT Executive
    Aug 2008
    Sunshine Coast
    ahhhh ok.
    should i defiantly get new ones?
    Joe
    VT Commy
    Mar 2010
    Adelaide!
    98 VT Executive
    Aug 2008
    Sunshine Coast
    hahaha cheers.
    sooo annoying. I use my car a lot for work coz im a mobile car detailer and I've already replaced clutch kit, water pump and coils in the past 6 months.
    Joe
    98 VT Executive
    Aug 2008
    Sunshine Coast
    Ok so i got a video/sound clip of it.
    I had the camera behind the front wheel near the suspension in order to get closest to the noise. You can hear it make a rattling noise.
    YouTube - VT engine mounts sagged
    Really hope this helps!
    PS: my exhaust -> YouTube - V6 VT commodore exhaust
    Joe
    Joe
    vr1uz-fe is offline Banned
    vr berlina
    Aug 2010
    australia
    i have replaced many engine mounts and as far as i know they dont fix any rattles
    but they need to be replaced when sagged
    98 VT Executive
    Aug 2008
    Sunshine Coast
    ok thanks mate,
    do you know where that rattle noise could be coming from?
    cheers.
    Joe
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    on your exhuast clip, does it usually take that long to start up? lol mite wanna check ya battery too
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    98 VT Executive
    Aug 2008
    Sunshine Coast
    mate, it usually takes longer
    apparently it's the fuel pump or something...not sure hey! pretty fustrating at the moment.
    Joe
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Quote Originally Posted by JoeFish View Post
    Id get that checked out bro lol does ur fuel pump make any weird noises?
    98 VT Executive
    Aug 2008
    Sunshine Coast
    haha yeah man it most times makes a buzzing sort of noise near the tow bar (presuming it's the fuel pump)
    Joe
    ve sv6
    Aug 2010
    if its a v6 the genuine engine mounts are liquid filled to dampen the vibration, over time these crack/split and the fliud leaks out and the rubber mounts compress and drop down. near the bottom of the mount there is a metal rod that will stop the engine lifting when the mount s##ts it self and that comes in contact with the x-member and cause a rattle and vibration thru the car, and as tree cutter said the sump can also hit the x-member. there are two type of aftermarket mounts that are avalible for the v6 being solid rubber and liquid filled imo i would recomend the liquid filled ones because of helping dampening vibration.
    glenn.
    98 VT Executive
    Aug 2008
    Sunshine Coast
    Thanks a lot for the help Glenn.
    Sounds like I really should get it fixed. I will take my car in next week and get it fixed.
    Also, if you know anything about drive chains, I have made a topic titled 'how to quiet down drive chain' or something similar. I have a video so you can hear the noise I am talking about.
    Just search for my name to find it - if you know anything about drive chains.
    Thanks a lot again mate
    Cheers,
    Joe
    Joe
  1. Unusual Or Rare Car Pics
    By Trevor 062 in forum The Pub
    Last Post: 31-03-2010, 07:43 PM
  2. Unusual pets
    By AirStrike in forum The Pub
    Last Post: 17-01-2009, 11:22 AM
  3. unusual rear end wobble
    By alimpyer in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 29-09-2005, 09:25 PM
  4. Unusual Noise
    By Kevin in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-02-2005, 10:53 AM
  5. Unusual Request
    By Troy711 in forum The Pub
    Last Post: 03-03-2004, 11:09 PM
