Results 1 to 3 of 3
Thread: vt wont start (immobiliser or starter motor) please help.
    VT Executive
    Aug 2010
    wooloweyah
    Default vt wont start (immobiliser or starter motor) please help.
    hi all, I recently bought a vt executive second hand it has a v6 ecotech . It needed a new auto trans. The old one only drove in first and reverse. Anyway I changed the auto and when I started it it sounded like the starter wasnt in properly and the teeth on the starter or ring gear was stripping. I took out the starter to find that the thin metal bash plate between bell housing and where it bolts up had bent and was rubbing the flex plate.
    When I went to start it again it the battery was pretty flat and starter made some horrible noises and wouldnt turn over. I dissconnected the battery and recharged it and now when I go to start it, It is just dead but all dash lights etc do go on.
    I tried the paper clip pinout and all I get is 12 so there is no extra info there and I did try leaving the key in the on position for an hour to no avail.
    So I was wondering if there is a fuse or something else I could try before a new starter or getting a new key programmed.
    Any help and suggestians would be greatly appreciated.
    VT Executive
    Aug 2010
    wooloweyah
    1998 vt commodore
    Jul 2010
    nsw
    what was cost to fix
  1. VT wont start ??? starter motor ??
    By Miss L in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-08-2010, 08:04 PM
  2. wont start, starter motor won even try to crank
    By vs1997II in forum Electrical Wiring / Questions
    Last Post: 30-06-2010, 09:31 PM
  3. squealling start: starter motor?
    By zai in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-03-2010, 08:04 AM
  4. Ecotec - Starter motor issues after jump start
    By Fonzie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-12-2009, 05:32 PM
  5. Motor turns over but wont start...
    By Stellaman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-01-2009, 09:36 PM
