Just a quick one, my friends VT Berlina (series 1) rear demister has suddenly stopped working. light comes on and everything but it doesnt do anything. Just wondering what we should check to try and fix it?
probably a relay check out the ones under the dash on the drivers side pull down the cover that surrounds the steering wheel work out which one is the demister and swap it for the one for you r power windows if you have em other wise swap it for some other when see if it works if it does easy fix goto holden car yard take the faulty relay tell em you want a new one should be about 7-8 bux
