Page 1 of 2 12 LastLast
Results 1 to 25 of 28
Thread: VT kicks over just wont start!!
    Red 1999 V6 VT Commodore
    Jan 2010
    Default VT kicks over just wont start!!
    hey guys, i have been runnin in and out of my house all day goin from forums to my car trying to work out why i just wont start, it kicks over well and there is with out a doubt enough power in the battery to start it, having 14V. I saw a few threads sayin give the starter motor a knock with a hammer, or turn my key right to the point before ignition leaving for abit then trying to start, but nothing seems to be working. so could it be starter motor, spark plugs? please help me
    Thanks guys
    vx s pack II
    Jan 2010
    aLKIDA
    Check for codes bridge pins 5&6.
    There could be no spark. Check for spark.
    If there is no spark it can be the DFI module/CAS or even the EFI relay.
    If there is spark the ignition side of things are good.
    It could even be a communication failure between the BCM/PCM.
    They talk to each other upon start up. The PCM enables the fuel system. Or even the PCM could be playing up
    VT S2 LS1 -VX S2 SS LS1
    Feb 2010
    IPSWICH
    knock the starter with a hammer is only if your starter motor is buggered. if your vehicle turns over does it start then stop or turns over but not start at all? if vehicle turns over then starts then stops immediately you might just have a buggered keyhead battery,if you have a spare key try that. if the vehicle turns over but doesnt start go through the last reply & see what happens.
    A pessimist is a man who thinks all woman are bad. An optimist is a man who hopes they are
    Jan 2010
    i could sit there and it just keeps kickin over and over, no start. ive tryed both sets of keys and yea, somethin muckin up.
    vx
    Jan 2010
    Jan 2010
    yea maybe, they have been droped a fair bit over the years, and they are the original keys from 11 years ago so wouldnt surprize me. how do i go about gettin a new key and all the rest?
    VX Berlina S2 Gen 3 V8
    Feb 2010
    Echuca
    VT V8 Calais
    Mar 2007
    Quote Originally Posted by sleepa View Post
    Does the fuel pump turn on?
    Was about to say, can you hear the fuel pump pressurize?
    50LTRv8
    RichoKidd's Avatar
    RichoKidd is offline Obese Commodores
    VT 3.6 2000 Executive
    May 2010
    Perth, WA
    Only way you can get them is to call Holden and give them your arm (or $550.00) Then you gotta get it coded (Another limb)
    Jan 2010
    umm im not to sure what to listen out for, whats it sound like when the fuel pump kicks in?
    I might just go to holden either way and get new keys, these ones are pretty f*cked lol
    Feb 2010
    Echuca
    The fuel pump should make a whirring noise a second or so after you turn it to ON. Turn the radio off so you can here it.
    Jan 2010
    just went out to try again, i can hear the fuel pump turn on, so i take it thats not the problem. I had a read through the owners manual, and it said to turn key to ON position ad leave for 2 hours turning all accesories off. i did this 2 hours was up tryed and still nothing! after it kicks over and i turn the key back off, i can hear this clicking sort of noise comming from the throttle body area. its really pissing me off lol. so thats were im at
    Jan 2010
    Quote Originally Posted by PRAVX II S View Post
    Hey mate sounds like ya now what ya talkin bout, how do i check for spark? and if there is spark how to i check the BCM and PCM?
    Jan 2010
    ive also notice, nothin comes on in the screen part of the dash. whats that mean?
  15. #15
    vt spac supercharged 6,vp bt1 5.0,vn v6
    Dec 2009
    east of melbourne
    Hi there so is your led turning off when you try to start it , and i take it your lcd screen isnt switch from klms to instants etc , mmmmm sounds interesting ,just guessing maybe your key barrel is worn, bcm is nackered. Have you bridge the diag connector to see if any codes have been spat out. Also could be a bad ground check you ground wires from battery to body and batter to engine block. Is your starter motor turning motor over just not firing or nothing.
  16. #16
    VT
    Jul 2010
    Central Coast, NSW
    i have pretty much the same problem but mine some time started some time keep kicking over and over,..
    just few things i realised, if i let the key in on position till fuel pump stop pressurised, i could not start the car but if i hop in and put the key in and started it staright away, it started (some time)
    So, if i couldn't started, i left the car there for few mins, and i can start mine again..
    can anyone help me too ? what could be the problems ?
    and thanks to Braddz93 to start the topic
  17. #17
    vx s pack II
    Jan 2010
    aLKIDA
    People if the car turns over but does not start you have to go through a process of elimination not guess work.
    First of all check the codes bridge pins 5&6. If there is no code then
    Check for spark. With a spark plug tester (Repco sell them)
    If there is spark then check for injector trigger this supplies the fuel in to the engine. (Use multi-meter) Make sure the fuel pump is working.
    If there is no spark check for EFI relay,CAS,DFI module,Coil pack.
    You need fuel/air/spark to fire a engine
  18. #18
    Jan 2010
    how do i check them pins? were are the etc, and also how do i check the injector trigger?
    checked for spark today and it has spark, fuel pump starts up aswell.
  19. #19
    VT
    Jul 2010
    Central Coast, NSW
    guys, mine happened again this morning, was kicking over and over and over but didn't started , tried it for like 5-10mins , then sudden started from nowhere .. i getting panic as don't know when the car gonna start or not gonna start ..
    another thing i realised , it alway happen only in the morning. also, after the car started i can switch off and i can start it again every time , never have any problems.
    thinking about getting new key but don't really wanna spend money if it won't fix the problem tho
    what you reckon about the injectors , could be leaking over night and flood the plugs ?
    Thanks for all ya helps
    VT
    Jul 2010
    Central Coast, NSW
    Quote Originally Posted by -_-" View Post
    Anyone ???
  21. #21
    magoo's Avatar
    magoo is offline magoo
    VU SS
    Jul 2010
    shellharbour
    Have you taken it to a mechanic, i reckon it a old kill switch thats been disconected and not totally removed and intermitting ,thats what happend to my ss and it had the same dramas .it most likely not it but just a thought
  22. #22
    VP Berlina
    Aug 2010
    vic
    It could also be the harmonic balancer sensor, try pouring water over it and then try starting it.
  23. #23
    VT
    Jul 2010
    Central Coast, NSW
    Quote Originally Posted by magoo View Post
    No, not yet. and don't think it's kill switch as i asked previous owner when i bought the car
    Thanks anyway
    Quote Originally Posted by B1OHZRD View Post
    no, don't think so cause it only happened in the cold morning
    Thanks anyway
  24. #24
    05 vz calais
    Oct 2009
    south west rocks, NSW
    hya mate i just recently had a similar problem, car would crank over easy but wouldn't fire n some times it would, it was mainly in the cold mornings and nights it was worse but it turned out to be my fuel pump relay under the bonnet was stuffed, so it wasn't pumping fuel thru so wasn't firing. try swapping your relay with the horn one and see if it works than, i had holden and lock smiths telling me it was my ignition barrel sensor or my key not reading etc but i checked a few other things and found out it was just a cheep relay not a $400 job to get my key and ignition barrel sensors etc replaced.
    cheers scott
  25. #25
    Holden VZ R8 Maloo 297
    Aug 2010
    melbroune
    your injectors could be rooted, cos sounds the same as what i had, and i just wasnt getting any fuel into the engine.
  1. vt wont start
    By vt62nv in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-04-2011, 09:09 PM
  2. VL wont start yet again..
    By <atomicL93> in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-12-2009, 11:56 AM
  3. vt 5.0 wont start
    By deanos70 in forum V8 Development and Modification
    Last Post: 29-11-2009, 01:00 PM
  4. VN starting problems, kicks over but wont run
    By Bz Kn33z in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-06-2008, 04:39 PM
  5. vt wont start
    By vt62nv in forum Electrical Wiring / Questions
    Last Post: 23-05-2006, 01:13 PM
