Hey guys,
I Went To Chip Control Once Upon A Day to Get A Tune, I Was Told I Needed New Injectors, Bigger Ones, For What Iv'e Got Powering The Car. Heres My Mods:
- Pacemaker Extractors
- 2.5" Custom Stright Exhaust With Dual Exhaust Chrome Tip
- Mace Engineering Custom Cold Air Intake
- Metalcat High Flow Cat 100CPSI
- Hedman Muffler 24" Straight
- Mace Engineering Custom Plenum Spacer 17mm
- Mace Engineering Custom Cold Air Inlet Manifold Spacer 25mm
- Mace Engineering Custom Bored Out And Polished Throttle Body 69mm
- Mace Engineering Custom 85mm Mass Airflow Meter
- Mace Engineering 1.9.1 High Ratio Roller Rockers
- 4" Pod Filter
- Bigger Water Pump
- Custom Cold Air Intake Piping Stainless Steel 4" W/ Silicone Elbows
- Custom Ported & Polished Plenum Cover
- Custom Ported & Polished Manifold
- Custom Polished Fuel Rails
- Transgo Stage 2 Shift Kit
- New Tranny
- Corvette Servo
- Top Gun 10mm Ignition Lead Set
- MSD Ignition 8224 Coil Packs
Just Wondering What Injectors I Can Buy To Put In The Car, Can i Put Blue Top V8 Ones In?
Don't Knock My Turbo Lag, It Gives Your V8 A Chance
you can get lucas 76 pounds pressure injectors for a v6,cost around 300 bucks
A pessimist is a man who thinks all woman are bad. An optimist is a man who hopes they are
Where can I get them from?
Cant remember where i got my last lot from as it was awhile ago. but check the link below for similar ones
LUCAS 72LB INJECTORS XR6 TURBO COMMODORE V6 like bosch - eBay Other, Performance Parts, Car Parts, Accessories, Cars, Bikes, Boats. (end time 26-Aug-10 19:00:32 AEST)
L67 injectors are pretty good flowing.
I can't believe that you would need bigger injectors for those mods. The only power maker here are these,
-And some porting.
You haven't listed some wild cam or anything so your stock injectors should be fine. What is you current dyno read?
Ronald Reagan (1986)
after thinking about it a bit acarmody is right,maybe your mechanic just wanted to get some more dollars out of you. unless you have a wild cam as suggested???
I doubt those mods would require going to a larger fuel injector. I would be checking the fuel system first to make sure everything is working and flowing correctly.
When you do things right, people won’t be sure you’ve done anything at all,,,,,,,,,
353RWHP L67 VS S Pack 6 Speed
Kalmaker Tuning Software N03 N04 N05 N06 N07 N08 W00 W10 W20 W21 W30 W31
W40 W41 W45 W46 W50 W51 W55 W56 W81 W85 W86 W91 W95 W96
