Results 1 to 19 of 19
Thread: VT light issue
    VTSS GEN3, VKSSA REP V8, VP BT1 V8
    Feb 2006
    darlington
    Default VT light issue
    hey guuys, just bout my 1st VT on friday. found out my tail lights wernt working coz the plugs holdn the globes wer broken, fitted new looms each side and put new double filament globes in but now when i turn my lights on the tail lights come on but so do the break lights without actualy useing the breaks and also my park lights come on in headlights when i use the breaks even when the lights are turnd off.
    any idea what could be the issue?
    cheers. Andy.
    BAD COP!! NO DONUT!!
    VX Commodore Lumina
    Jan 2006
    South Adelaide
    Well you must have connected up a wire incorrectly somewhere, that's the only thing it could be.. You may have connected the parker circuit to the brakes part of the tail light (instead of the tail section).
    I would pull the loom out and check your wiring, then check it again.
    Mick1988's Avatar
    Mick1988 is offline W.A. Cruise Moderator
    Too many to list......
    Apr 2008
    Perth, Western Australia
    What he said... and double check the H4 globes in your headlights are installed correctly. I've diagnosed a mates car with random lighting issues before and he had plugged one of the H4 headlight globes in wrong.
    VX2 Executive Sedan - 3.8L Auto (for now)
    VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)
    VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
    Feb 2006
    darlington
    hmm not sure coz all i did was unplug the old loom n plug the new 1 in, but ill disconect em n double check it
    VX Commodore Lumina
    Jan 2006
    South Adelaide
    That's the best thing, disconnect it all, and re check. If you have a 12V circuit tester, then use that and a mate to check what each of the stock wires in your car do, then visually check to make sure the wires on the loom will connect to the corresponding stock wire.
    Do your parker lights come on when you press the brakes with no loom attached? (So your brake lights won't work, but it's just a troubleshooting action to see if the loom is the problem, or if you need to be looking elsewhere)
    Feb 2006
    darlington
    ok we just disconected both looms and the park lights didnt come on when the brakes wer used, but we disconected the rear looms 1 at a time and still had the same issue and swapd them side to side and still had same issue, my auto elec had a look and thinks the looms i was given wer for a differeant light set up, so have genuine looms matched to the VIN number on order so if they dont fix the problem i no theres sumthin more internal
    VX Commodore Lumina
    Jan 2006
    South Adelaide
    Why don't you do some wire cutting and try to fix it up yourself? It's not like you can use the loom anyways, so if you stuff it up, you can then order a proper one.. Then you might be able to save yourself some coin..
    Decent quote to follow: "If it doesn't fit, force it. If it breaks, it needed replacing anyways" lol
    Feb 2006
    darlington
    umm coz my knowlage of auto elec is that ya dont cross red and black wires lol
    VX Commodore Lumina
    Jan 2006
    South Adelaide
    lol fair enough.. It's really simple though.. But I guess that's because I've tinkered with it before, so I know what I'm doing.. But all you need is to give it a go, then you'll get more confidence and then before you know it, you'll be pulling your dash apart and playing with wires in behind there lol
    Feb 2006
    darlington
    haha yer i no wat ur sayn but i just dont wanna take the chance at the moment lol dont have a lot of cash comen in to fix my f**k ups lol last time i tryd this stuff i cut a wire for the imobilisor n had to fork out for an auto elec to get fixd just to start the car lol
    VX Commodore Lumina
    Jan 2006
    South Adelaide
    lol, well there is no chance of cutting an immobiliser wire in the break lights. Just don't cut the stock wires, only cut the wires in the loom that you bought.. just get the ground connected correctly and then you shouldn't have any problems, unless you hook a wire to a wrong connector, in which case the correct light won't work, but you're not going to blow up your car, trust me .
    Feb 2006
    darlington
    haha if these looms i jst orderd dnt plug in n fix the issue cuttn things will be the next step
    VX Commodore Lumina
    Jan 2006
    South Adelaide
    aight then mate. If that's the case, then it will help for you to get a 12v circuit tester too. They're like $5 from cheap as chips.. It's like a pen with a metal tip, and a chord that plugs into the top of it, with an alligator clip on the end of the chord. Very handy when working out which wires are active when certain lights are on..
    Feb 2006
    darlington
  15. #15
    Mick1988's Avatar
    Apr 2008
    let me know if you need any wiring diagrams mate.
  16. #16
    Feb 2006
    darlington
    oh nice, cheers heaps, looms should be in round 3.30 so yer if that dont help ill send ya a msg
  17. #17
    Feb 2006
    darlington
    well plugd in the second set of looms and everything workd as it should straight away.. cheers for the advise guys
  18. #18
    2002 VX SS 235 Cammed 305rwkw
    Jun 2008
    Feb 2006
    darlington
    thanks for usen my thred to jack up ur post count tommy lol
  1. light issue
    By mrvdv in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-08-2010, 08:08 PM
  2. vp 5.0L has oil light issue
    By VP 5.0 BERLINA in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-06-2010, 08:42 AM
  3. VT Brake light issue
    By valiant in forum Electrical Wiring / Questions
    Last Post: 02-05-2010, 10:03 PM
  4. VR with intermittent Air Bag light issue
    By chrrr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-08-2008, 07:35 AM
  5. another light issue!
    By 5spdVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-06-2005, 09:39 PM
