Results 1 to 17 of 17
Thread: Holes left after removing VT-II Calais spoiler?
    VE Calais V, VT-II Calais
    Aug 2010
    Default Holes left after removing VT-II Calais spoiler?
    What size are they?
    I want to source some plugs and say goodbye to the POS.
    thanks
    VX S S/C & BA XR6T
    Feb 2009
    Get the holes flushed over and painted.The rubber grommet look is a bit tryhard imo and reaks of half arsedness.
    Maybe sell your boot and replace with an executive item.If the path is of utter importance straight away the Clark Rubber or such stores will stock them,local auto should aswell.
    VT Acclaim Wagon
    Oct 2008
    most spare places stock bolt in grommets/plugs for putting in radio aerial holes. these would do the trick but not look to flash
    00 SS M6/79 chev Monza
    Mar 2005
    it is still going to look like shite
    you can actually do something better than tape or plugs
    use sime tape under the holes and get your trusty soldering iron out start out by dropping solder on to the tape and gradually as it builds dip the soldering iron in to the blob you have made ,it will heat the area up BUT not enough to damage the paint ....should be able to get it to look better than just crappy plugs ! then just use some touch up paint
    Aug 2010
    The reason Im dumping it is because it is broken and rattles, and the paint has crapped itself as well..... not to worry though, because the shite paint will match the back bumper as well :S
    Trust me, the plugs would be an improvement.
    Id get it resprayed, but Ill be damned if Im gonna drop thousands into a VT-II Calais
    VT
    Jul 2010
    Central Coast, NSW
    Mate, just go to any auto shop and look for champion stand , you looking for blanking grommets , part no BH018 , 3/8 size and has 4 in a pack , but you need 5 grommets
    hope this help
    magoo's Avatar
    magoo is offline magoo
    VU SS
    Jul 2010
    shellharbour
    solder it even a bodge spray, cut and polish with some clear will look better and they wont charge thousands for a boot spray any way . even a touch up guy could paint it after you solder it
    was: VZ SV6 M6 2004 is: VX SS M6 2001
    Mar 2009
    Getting it professionally done wont be thousands, and you could properbly get the bumper done at the same time... give your car abit of value back.
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
    Someone already mentioned it. For the time being go to a shop that has the champion stand and get the grommets. Will cost you MAX ten bucks for a pack. Then later on you can always take the spoiler to get it resprayed and take out the grommets. I reckon that solder is even more bodgy?
    carless for now
    Feb 2007
    perth,Western Australia
    Quote Originally Posted by -_-" View Post
    hope this help
    is the wiring hole the exact same size as the holes for the spoiler?
    VT
    Jul 2010
    Central Coast, NSW
    Quote Originally Posted by Vt_vic View Post
    Yes, but i have S pec spoiler on mine
    1996 3.8L VS Commodore
    Aug 2010
    Watanobbi
    awww this hurts me to see people talking about putting rubber in holes why dont u just go all the way and polyeurathane it... no that was a joke. why dont u just go down to bunnings or mitre 10 and grab yourself a little tube of plasti bond which comes in a package with hardener, it takes 3 seconds to mix, dries like metal in about 5 to 10 minutes depending on how thick u cake it on then sand it and go down to your local spare parts place and get em to match u up a pressure pack of your colour (u will find the colour code on your VIN plate unless there is a seperate plate on the other side of your firewall) and grab a pressure pack of auto clear and bam your vt is nice again, u could then use whats left of the colour match to do your bumper and all of this will probably cost u about 50 bux if that
    HX Kingswood Ute (Project)
    VN Berlina (Now a Donor)
    "91 Subaru Liberty (Blown Motor Ex-Daily)
    VS Commodore (Daily)
    98 VT Exec
    Jan 2010
    Redbank Plains, QLD
    Aug 2010
    jw, dont laugh, my dad use to solve rust holes on his HK wagon with a tube of sealant and things like bolts that fit into the hole
    The problem is, if I get the boot/bumper/spoiler resprayed, it wont match the rest of the car Id have to get the whole car resprayed, and that *will* cost thousands....
  15. #15
    Aug 2010
    Watanobbi
    Quote Originally Posted by devnull View Post
    hahaha i love it, thats gangster if only it was that easy in nsw
  16. #16
    VT Acclaim Wagon
    Oct 2008
    Just look in a few wreckers and get a second hand boot lid the same colour. $50 or $60, problem solved
  17. #17
    missus (in more ways than one)
    Sep 2005
    On another note make sure you replace your parcel shelf with one with a brake light, as my canary from the weekend included the fact I didn't have an eye level brake light ( removed spoiler from vxss) and from reading Vicroads etc, theve been mandatory since the 90's. Oh and it's always good to avoid a yellow reason
    selling victorian number plates MADVN6,
    pm me if interested
  1. Replies: 5
    Last Post: 13-07-2010, 01:11 AM
  2. removing spoiler on VX Calais HBD bodykit
    By hsv_6ltr_sette in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-09-2008, 10:25 PM
  3. Spoiler Fitting screw holes on inside of boot - VT
    By jbray1984 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-02-2007, 01:05 PM
  4. VX SS Spoiler fit VX S holes????
    By grimavxs in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-01-2007, 09:40 AM
  5. Holes in Boot from removing Spoiler
    By hothouse vy s in forum VY Holden Commodore (2002 - 2004)
    Last Post: 07-05-2006, 07:38 PM
