Results 1 to 15 of 15
Thread: VT Low running temperature
    VT Berlina
    Aug 2010
    Default VT Low running temperature
    Hi guys, I just bought a VT Berlina, great car, but I'm having a strange issue with the temperature. It is taking a long time for the car to warm up, you can drive for a good 15 minutes before the gauge begins to move, and then it never goes above the first line. The economy seems to be fairly poor while it is warming up, and then improves quite a bit once it finally warms up. Does this sound like a thermostat issue?
    VP Berlina
    Aug 2010
    vic
    is it blowing any smoke? It's most likely to be the thermostat, if it is the thermostat, than it'll cost like $25.00 to fix, gud luck!
    99 VT Sedan
    Feb 2010
    Quote Originally Posted by daver00 View Post
    Yeh sounds like there is no thermosat in there...
    Or stuck open...
    But be careful when installing a new one to bleed the radiator
    99 VT Sedan
    Feb 2010
    Quote Originally Posted by 11gothevt11 View Post
    Or stuck open...
    Also you can buy low tem thermosats ...I have a 82 degree one
    I only have this as it runs 10 degrees lower than stock.....But when my car gets to 92 /94 degrees ..I know its time to top up the radiator....I have done pressure test found 3 tiny leaks in the hose...Replace them also new radiator cap..Rated 120 kpa...commodore manual says sould be 135 kpa...Any way my problem is water gets drawn into the overflow and doesn't return it back to radiator...I have put the air pressure hose through overflow pipe...(thermosat and radiator cap and replacement hose's under one month old).But i'm all out of idea's ??????? Can anyone suggest anything els???????
    vr1uz-fe is offline Banned
    vr berlina
    Aug 2010
    australia
    dont look at it that might help
    o and with the bleeding a good rev will get the air out and a imean a 30 min drive hitting 5000 all the time very fun
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    Ifit isnt sucking coolant back out of the overflow bottle you have a leak in your cooling system. After you take your car for a run and turn off the engine, feel under the waterpump to see if any coolant is dripping out the little drain hole underneath. If it is leaking you need to replace the water pump. Also check around your heater tap and the bottom of your inlet manifold for any white or green stains from a coolant leak.
    VX2 Executive
    Nov 2006
    Kallangur, Qld
    if it does have a thermostat it could just have a low temp thermostat in it. I have a low temp thermostat in mine and the only time it goes above the frist line is when i am stuck in traffic, and on a cold morning it can take up to 20mins before the needle starts moving. good luck with it.
    VT
    May 2010
    Make sure that you have the correct pressure radiator cap and that it is working correctly. If the cap is too low then the car cooling system will not build up pressure and will not heat up correctly. When I bought my car it had a 90kpa cap on it so it was having the same issues yours is having. Swapped it out the a 135kpa one and it works a treat.
    Also check for leaks as others have stated some small leaks like the water pump or the heater hose O-rings can be hard to find as they will leak onto a hot engine and dissapear. Usually a pressure test of the cooling system will find these issues.
    99 VT Sedan
    Feb 2010
    Quote Originally Posted by thepowerman View Post
    What temp is your thermosat???? I have 82 degrees one...Mine takes around 10 minutes to reach 82 degrees....Do you also have a 135 kpa cap??? Have you changed your radiator??
    VT Berlina
    Aug 2010
    An update: I switched on the special menu features this morning on a cold run, the car took a couple of minutes to get up to about 55c, but then it started going up and down between 54-56c. A few more minutes and it got up to about 62, but again hovered between 60-62, it really looks like its cooling itself down at way too low temperatures, ie thermostat stuck open or missing. I stopped for petrol and had a quick check with the engine running, now both thermofans were on together with the engine at 62c, and they both switched off together when it cooled to 60c, is this right, because it seems wrong to me? Does it seem like someone has wired the two fans together?
    Anyway I've got a new thermostat, will go and change that when the car cools down.
    Edit: the radiator cap is 135kPa and I'm positive that no coolant is leaking anywhere, not blowing any smoke either.
    jujibelly's Avatar
    jujibelly is offline ERROR_PATH_NOT_FOUND
    Vr Commodore
    Apr 2009
    Melb
    VT Berlina
    Aug 2010
    Quote Originally Posted by jujibelly View Post
    ECT sensor. $10 bucks from Holden.
    Do you think thats the whole problem? Or the reason the fans are coming on at the wrong speed?
    VT Berlina
    Aug 2010
    VX2 Executive
    Nov 2006
    Kallangur, Qld
    i think mine is a 79deg thermostat. i replaced it when i blew my last radiator. i bought a brand new 135kpa cap when i bought the new radiator and the mechanic also flushed my system 3 times for me just to get all the **** out and pressure tested it when he put it all in for me. I just drive it quietly until it is warm, so i dont do any damage at those lower temps.
  15. #15
    richardpalinkas's Avatar
    richardpalinkas is offline Blown Alloytec
    Raptor Impulse VZ SV6
    May 2009
    Gold Coast
    my vx used to stay on the first line for ever unless im caught in traffic, but on the highway, it never moved
    Spoken by a true member of The Committee
  1. VP normal running temperature
    By skunks.monks in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-02-2010, 09:33 PM
  2. VP running rough when at operating temperature..
    By firefox45 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-08-2009, 06:16 PM
  3. Engine Running Temperature
    By VZ05 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 27-03-2008, 04:03 PM
  4. Question on running temperature V6 - VS
    By zapper in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-10-2007, 08:24 PM
  5. running temperature of coolant?
    By rgormley in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-04-2005, 04:26 PM
