My VT's front caster rod bushes need replacing.
I have read that the originals are oil filled for better ride comfort.
If I replace them with urethane will it make the car ride worse - handle better.
Current setup is FE2 factory.
Are some brands better than others
EG: Whiteline, Pedders, Nolathane, Superpro.
Some are a black/blue colour whats with that?
There is a full set (F&R) of Nolathane bushes, strut tops on ebay for $290
I dont need most of the stuff, but for the extra $, I am thinking of getting the lot.
there all urathane and whiteline pedders nolathane are all made in the same place but pedders has now relased a rubber version for comfort and only pedders has these rubber ones
Changed my strut tops 3 times in 126xxx km as well as the Castor bushesF/R, Zbar bushes, sway bar & link pin.
- Had to use stock item for the strut tops(car was under warranty) and only lasted 35k.
- Next time with pedders shite for the Strut tops & Front Castor/Radius, ride was a nightmare and cost too much I thought.
- I did them myself, used superpro for the Strut tops/Rear castor, Link pins, sway bar & Zbar and OMFG it actually feels great and the cars ride is perfect.
Superpro over Nolathane/Whiteline over Pedders over stock... would be my choice and the price diff is marginal.
Just my 2c...
i have found rubber strut tops to be far supierior over urathane
Use Nolathane for your front castor rod bushes. They are much better than the original items and can be adjusted to give you the correct amount of castor.
I replaced mine a while ago with Nolathane bushes ( the red ones ) have a look at this write up i done on it . It was pretty sraight forward . Just one thing though , when you take off the old nuts and bushes count the number of washers that are installed . some have 2 per side and some have 2 on one side and 1 on the other side .I thought i left one of the old ones on and pulled the whole lot off again only to realise that there was 1 missing to start with . Cheers Dave C How To Replace Radius Rod Bushes VT / VZ
Nolathane, Whiteline or superpro will all shit it in over the stock caster rod bushes. They all do the same job the same way. No oil damping but solid urethane is the go
VYII Calais L67
Don't wast your time or money replacing with Rubber....... Nolathane is the best
Redranger Nolathane for longer life suspension systems - performance handling and suspension products. car shock damper swaybar sway bar anti-sway bush bushes australia australian automotive performance road holding turn-in camber caster toe in vehic
It will handle heaps better with Urethane but ride will be harsher. If you like performance do it. They are a bit easier to fit than rubber in a lot of places too.
the factory rubber/liquid filled bushes are crap even when they are new, there is so much movement in them, to test them drive forward in your drive way and jump on the brakes, with someone watching they will see how far back the wheel moves and when you let go of the brake they will see how far forward the wheel jumps.
i have just replaced mine with the nolathane bushes along with every other bush in the front end. Deffinitely handles better and ride is harsher, but only a little harsher. so i would def go with the nolathane ones again.
Don't go for ride comfort if you have fe2 suspension, go urethene. I agree with other posters, go rubber strut tops.
I had the caster bar/radius rod bushes replaced in my VX SS with Superpro, first thing I noticed was how good and positive the car felt on the road, big improvement, I was a bit concerned about the ride/comfort side of things, but to be honest I don't think it has made much difference to the ride, maybe a tad firmer but not much difference at all.
Nolathane wins hands down everytime,worth every!!!
sorry to cut in here but whats the best option on engine mounts? ive only seen rubber ones thats all.
Check out my ride here >>>>My VX Raptor
say NO to chev badges
Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
Use NOLLY its great stuff, i usd to work 'em.
hang on, make that..."i used to work FOR 'em"
TTTperformance offer both solid rubber bushing and nolathane engine mounts
TTT Performance Engineering Leaders in engine performance upgrades
VYII Calais L67
thanks but i didnt fine any thing to do with mounts on that website
thanks for that link.... $120 each thats abit pricey dont ya think?
soon as though everyones discussing bushes and stuff... i have a question, i swear by nolathane only because its all i have ever used, i stick with what i know and an enhancement kit is to expensive just to experiment with haha but i was offered an enhancement kit for a vs cheap as chips, i was curious as to wether or not they would fit in a vn, i cant see anything that would be different like bush wise... does anyone know any different? or should i just buy it and find out the hard way...
HX Kingswood Ute (Project)
VN Berlina (Now a Donor)
"91 Subaru Liberty (Blown Motor Ex-Daily)
VS Commodore (Daily)
vb-vz use same lower iners and outers that is it well the bushes are slightley differnt but all dimensions are the same
