Results 1 to 2 of 2
Thread: vt overheating HEEELLLPPPP
    Joshcovl is offline josh
    VL executive,vt
    Jun 2009
    gold coast
    Default vt overheating HEEELLLPPPP
    On Friday my v6 vt started over heating the gage would go up rapidly over 80km but the heat would reduce rapidly when I slowed down. I have changed the themostate & done a full flush several times & replaced with high quality coolant. The car gage sits lower now but It still stays over heated quickly, but it doesnt go up and down rapidly it just climbs & stays there. There is a leak but I cant find where its coming from just see coolant on the ground although i have inspected the water pump and it appears fine. When I squeeze the bottom hose the radiator cap makes an air noise. Could the cap cause over heating and loss of colant when car is off? All I can think of is a problem with the radiator or the head gasket? There is no bubbles in the radiator... Im clueless. Please any advice.
    Cheers,
    Josh
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    A leaking radiator cap can cause problem because the system can't pressurize properly, replace it. Also have you bled the system properly to ensure you have no air bubbles in the system?
    Ronald Reagan (1986)
  1. Air Con and Almost Overheating
    By Feral01 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-10-2010, 04:03 AM
  2. my 92 vp is overheating
    By nuskoolVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-09-2009, 01:12 PM
  3. my 92 vp is overheating
    Last Post: 21-08-2009, 01:12 AM
  4. overheating with ac on
    By international95 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-08-2009, 11:12 AM
  5. Overheating?
    By Mr_Slim in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-02-2007, 03:07 PM
