Results 1 to 4 of 4
Thread: vx normal temp gauge reading
    Feb 2004
    Default vx normal temp gauge reading
    G'day to all,
    I did search but couldn't seem to find an answer.
    My wife drives a 2001 VX Commodore. Apart from being on gas it's stock. She seems to think that its running slightly warmer than it usually does. I don't drive it that often so I can't remember where the needle should sit.
    So I took it for a drive. The needle sits somewhere between 1/4 and 1/2 once warmed up. Is this normal?
    Thanks for your time.
    Cheers.
    2002 vx II Spack
    Feb 2010
    sydney
    yeah mate thats normal. anything higher than 1/2 or 3/4 i would be worried.
    VXSS
    May 2007
    with the car turned off, hold the mode and up button in and start the car, once running when you hit mode it will take you through the other things in the dash, eg volt readings, L/H fuel usage, digital speed, and also digital temp, plus a dash test mode. mine normally reads 92 deg.
    Feb 2004
    cheers.
    Again, such a great website for this sort of information.
  1. Temp gauge reading to high.
    By 1998GTS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-06-2010, 06:26 AM
  2. Temp gauge reading to high.
    Last Post: 17-03-2010, 03:20 PM
  3. temp flashes hot and then goes bak to normal temp?
    By shifty_90 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-10-2009, 09:50 PM
  4. normal running temp for a VT 5L? and temp gauge..
    By mike49 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2009, 12:57 AM
  5. Temp. gauge reading
    By vs_ute_89 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-09-2008, 09:26 AM
