Results 1 to 8 of 8
Thread: Low beams not working
    Nissan 300ZX TT
    May 2005
    Default Low beams not working
    Hey guys, got a strange problem with my headlights. First click, (parkers) works fine. Next click, (low beam) dont work but If I push the highbeam stalk forward and turn the dial to the lowbeam position, everything works ( every globe in the headlight)
    Ive checked the relays and fuses but cant seem to figure it out. I bought the car like this so I dont know if they ever worked.
    Any ideas?
    EDIT: car is a VT
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Have you tried another relay? I know you said you checked it, but thats seriously what it sounds like to me.
    Ronald Reagan (1986)
    Nissan 300ZX TT
    May 2005
    I tried the horn relay as they are the same type and no luck. I even put the horn relay in the headlight spot an still the same. I can feel and hear it clicking so i have no idea what else it could be. I havent had a chance to look at it today as ive been a little busy. A wiring schematic would be pretty handy right now.
    VXSS
    May 2007
    sorry not the best pic but hope it helps you out. I have included the executive to berlina and the calais wiring.
    VXSS
    May 2007
    Nissan 300ZX TT
    May 2005
    Thanks mate, I havent had a chance to look at the car yet. Looking at the pics it shouldnt be to hard to find the fault.
    VX Berlina 3.8
    Jun 2009
    I had a similar problem with just one headlight. Turned out to be the plug in the back of the globe had got wet at some stage even though they are sealed to a degree. This caused an intermittant connection. Open the circular cover on the back of the headlight assembly, disconnect the plug and check the metal contacts inside the plug for integrity and position as they can be pushed out of place when reconnecting. See how that goes....
    Statesman woodgrain dash, Calais Leather Interior, VY Berlina Wheels
    Commadore VT
    May 2012
    I've got this exact problem.
    I've checked the relays and fuses, checked the globes, the parkers and high beam lights work fine....but the low beam won't work!
    I don't have a clue what it could be although I just found this:
    8. Some VT's may have starting issues caused by a defective Fuel Pump relay (or have no low beam headlights, as the Low Beam relay is the same as the fuel pump relay). A revised relay was introduced late 2000. In case of starting or headlamp problems, the old relay (92047112) should not be used.
    Relay - Part number 92107897
    Taken from here:
    Faults - VT Electrical
  1. VZ low beams off when high beams on
    By BigBro in forum Electrical Wiring / Questions
    Last Post: 01-09-2009, 07:50 PM
  2. ve sv6, high beams? help
    By acca00 in forum VE Holden Commodore (2006 - ?)
    Last Post: 22-05-2009, 11:15 AM
  3. No low beams
    By LJS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-08-2008, 01:41 PM
  4. High Beams
    By SNY.3LT in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-10-2005, 10:41 PM
  5. VR High Beams
    By AirStrike in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-05-2005, 03:47 PM
