Results 1 to 5 of 5
Thread: help air con not engaging.
    VX2 Executive
    Nov 2006
    Kallangur, Qld
    Default help air con not engaging.
    was wondering if anyone had any ideas why the a/c pump on my VX II v6 wont activate, when i push the button the light comes on and the thermo fans kick in, but the pump doesnt activate. It started 6 months ago as an intermittent problem, just wouldnt kick in every now and again so i got the system regassed and new filters put in, and it worked fine for about 4 weeks and then went intermittent again and till the point where it wont activate at all.
    Would this be a dead ac pump, or could it be something small that can be easily repaired??
    any help will be great thanks.
    00 SS M6/79 chev Monza
    Mar 2005
    do a search
    could be a number of things ,did the ac place that re gassed your system put a dye in it ? if so go buy a cheap ultra violet light and check for flouro dye spray in your engine bay
    compressor
    tx valve
    condensor
    leaky hose
    leaky "O" rings
    evap unit
    welcome to the world of vt commodore air con repairs ........hopefully yours is simple .............next weekend i get to remove my complete dash to replace the evap unit (also doing heater core as well )
    good luck
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    The compressor clutch in mine died, maybe the same for you?
    Ronald Reagan (1986)
    VX2 Executive
    Nov 2006
    Kallangur, Qld
    i did do a search and didnt come up with anything useful . acarmody how much did they charge you to get the clutch fixed, just so i have an idea what price range i will be up for
    executive vt 5.0lt
    Feb 2005
    west suburbs
    id say that the gas has ecaped , i think mine needs a regas as same as yours the pump wont click in
  1. heater tap not engaging due to no suction.
    By pillzor in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-01-2011, 05:18 PM
  2. Vs Cruise control not engaging..
    By sxy677 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-07-2009, 01:10 PM
  3. Cooling fan not engaging
    By Wynnie88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-05-2009, 11:07 PM
  4. VN Aircon Re-Engaging
    By Melfice01 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-03-2006, 03:01 PM
  5. auto not engaging when cold
    By willi in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-05-2005, 05:57 PM
