Results 1 to 6 of 6
Thread: Power Windows suddenly stopped
    VT Berlina
    Aug 2010
    Default Power Windows suddenly stopped
    hi guys, just got in the car and put the rear windows down, then all the windows stopped working! no intermittent problem they just all stopped at once. Swapped fuse and relay and I'm sure its neither of those. Help I can't lock my car!
    VT S2 LS1 -VX S2 SS LS1
    Feb 2010
    IPSWICH
    normally if they do just stop it is a blown fuse or relay. if switches front & rear dont operate any windows,i would check things over with a multimeter
    A pessimist is a man who thinks all woman are bad. An optimist is a man who hopes they are
    VT Berlina
    Aug 2010
    I swapped relays over from the blower and the rear demister, no dice. Swapped the fuse over from the power seats, again no dice (and the power seat continued to work). I did notice though that when you try and operate the power windows, the power window relay get really hot really quickly. I'll check the switches for power I guess.
    Feb 2010
    IPSWICH
    You could have a bad earth somewhere,relay normally produce a little heat but not excessive or quickly
    VX 'S' S1
    Apr 2005
    South East,Victoria
    JUst had a look in the Haynes repair manual and it says there is a fuse , relay and a circuit breaker for the power windows . Have you checked all three ?
    VT Berlina
    Aug 2010
    Thanks guys. I went and pulled some stuff apart, one of the connections to the centre console switch looked bad, cleaned it up and it all worked. I was a little freaked out for a second there.
  1. How to put power windows door on non-power windows car?
    By deXtrous in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-04-2010, 05:35 PM
  2. Options..power seats... power windows??
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-01-2010, 06:01 PM
  3. Power steering stopped dead but everything else is fine!
    By pjdm1980 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-11-2009, 01:56 PM
  4. VR power steering stopped..
    By vrcommozone in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-08-2009, 12:14 AM
  5. driving along when suddenly all power is lost
    By arc angel vn ss in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-05-2009, 08:40 PM
