Results 1 to 10 of 10
Thread: Pulley noise!!!
    vx lumina
    Sep 2010
    adelaide
    Default Pulley noise!!!
    HI ALL,
    i hope some one can help me i am hearing what appears to be pulley noise but i can not tell what pulley it is the car is a vx lumina 6 2001 how can i tell if it is pulley it is not real noisey yet but just want some ones in put on how to tell if a pulley is stuffed
    thanks in advance
    VT 2
    Nov 2008
    Easiest way is to use or make a mechanics stethoscope.
    Steel rod into the end of a piece of narrow hose will do it. Put probe (rod) on the mounting bolt of the pulley and stick the end of the hose in your ear. It will sing like a soprano on speed if its stuffed.
    DLFHUB666's Avatar
    DLFHUB666 is offline Got Milk ???
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    vx lumina
    Sep 2010
    adelaide
    Hi Guys
    cheers i will give that a go amd let you know how i get on thanks heaps.
    VT S2 LS1 -VX S2 SS LS1
    Feb 2010
    IPSWICH
    why dont you just remove your fanbelt then check the pulleys for play,noise etc 1 by 1??? thats all i ever do & it works every time. chances are if you got what you think is pulley noise its a buggered idler pulley
    A pessimist is a man who thinks all woman are bad. An optimist is a man who hopes they are
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Common ecotec problem. Best bet is change them all that way you know yourself they are all good for the long haul.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
    Jarrad is offline Sherminator
    Silver Ex Cop VX Wagon
    Oct 2006
    Wollongong
    How much do you reckon it would cost to get them all done? I have a squeeky pulley too.
    Quote Originally Posted by monkeys437 View Post
    Its faster to drive very slowly than walk very quickly so hang onto your license and drive like a grandma for a year.
    Now you see me... Now you don't
    VT Acclaim Wagon
    Oct 2008
    western filters does a Gates pulley set with a new belt for the V6 for $90. or if u not close to Blacktown in Sydney, plus $11 postage. Supply only but their easy to diy.
    http://cgi.ebay.com.au/VT-V6-GATES-B...#ht_1553wt_836
    Or zaccsbearings does just the idler pulley and new belt for $27 plus $5.50post and you can get extra pulleys at checkout
    http://cgi.ebay.com.au/COMMODORE-VT-...#ht_1554wt_794
    Oct 2006
    Wollongong
    Thanks Graham.
    VL V8 & supercharged VX
    Nov 2006
    western vic
    if u replace them put the new steel ones on as u can reuse them . press a new bearing in them. way cheaper if it happens again.
  1. weird pulley noise coming from front of engine
    By muney in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-06-2011, 12:37 PM
  2. rattling pulley engine noise when idleing
    By Rider5 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-05-2009, 06:54 PM
  3. New A/C idler pulley making noise
    By aceventura in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-02-2009, 09:30 PM
  4. Vr commodore pulley noise
    By jasman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-02-2007, 03:29 PM
  5. VT V8 Gen3 noise near top pulley and radiator hose
    By bails in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-08-2006, 06:40 PM
