Results 1 to 12 of 12
Thread: Creaking Noise
    MikeCuzzy's Avatar
    MikeCuzzy is offline How hard can it be?
    2007 VE Omega 3.6L & 1998 VT Executive 3.8L
    Jan 2010
    Wollondilly, NSW
    Default Creaking Noise
    Hey guys,
    New problem with the old girl :P
    Recently I have noticed a creaking sound from the front right wheel area. Sounds like a joint is creaking, wondering if there is a common fault that might cause this. Sounds like it might be something in the suspension.
    It only seems to happen when that wheel moves up or down indepentantly of the car, i.e. speed humps, pot hole such like that.
    My first thought was something with the sway bar, any thoughts would be helpful.
    Thanks in advance,
    Mike.
    The New Ride - The Class 2 Shuttle Craft (VE)
    Timmy was a chemist's son, but Timmy is no more, for what he thought was H2O was H2SO4...
    VR Executive
    Sep 2010
    The 'Switch'
    stabilizer bar rubbers.. ?? Sounds similar to a noise I had just b4 the driver's side rubbers went..
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Thats my guess too , Had same prob and changed mine to nolathane now its all good
    VZ SV6 & a ZX6R
    Apr 2010
    Bathurst NSW
    VT II Clubsport R8
    Jul 2010
    I would be interested to know, i also have a creak or click nose in the front when the front of the car lifts or a tight turn and accelerate.
    I have done bearings plates and rubber, all bushes in the car, the only thing left is the strut themselves and the springs???
    VX S series II
    Sep 2010
    I've started getting a noise in mine as well.When driving over the judder bars at work or pot holes in the road.
    It's more of a metallic noise though,Like a bolt has worked loose a bit and it clunks.
    The steering has also started to shudder a bit when turning full lock or cornering at slow speed.
    ve sv6
    Aug 2010
    guys, another thing to check is a little stiffner brace that goes from the fire wall to the chassis rails, its a little galvinised coloured thing that 45* to the fire wall to chassis rail. if this is the problem there are 4 13mm headed nuts that hold it on and some times all they need is to be tightened slightly like an 1/8 of a turn and it can stop the noise. it sounds stupid and i wouldnt beleive it if i didnt know but have done heaps of them and 80% of the time this is it.
    VR Executive
    Sep 2010
    The 'Switch'
    Quote Originally Posted by JRNZER View Post
    yeah mate sounds like mine when the rubbers went on the stabilizer bar, might wanna get under n have a look see...
    MikeCuzzy's Avatar
    Jan 2010
    Wollondilly, NSW
    I should note it also occurs under moderate and higher braking.
    Which makes me think even more it may be something with the sway bar, any more thoughts?
    ve sv6
    Aug 2010
    MikeCuzzy's Avatar
    Jan 2010
    Wollondilly, NSW
    Quote Originally Posted by glenn l View Post
    have you checked your x-member bolts.
    Actually didn't think of that (there's inexperience for you).
    VX S series II
    Sep 2010
    Quote Originally Posted by LilMs View Post
    Thanks man.I'll check that out this weekend.
  1. Creaking noise at high speeds?
    By demuck in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-07-2010, 11:55 PM
  2. Clutch Creaking
    By simon_bogle in forum VY Holden Commodore (2002 - 2004)
    Last Post: 26-10-2009, 11:32 PM
  3. Brakes creaking when hot
    By aceventura in forum General
    Last Post: 15-02-2009, 12:33 PM
  4. creaking noise when turning
    By freddys in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-01-2007, 11:53 AM
  5. Creaking Front End
    By VT TOMMY in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-09-2005, 09:55 PM
