Results 1 to 6 of 6
Thread: ignition key, again
    VT Acclaim Wagon
    Oct 2008
    Default ignition key, again
    had a look thru posts and nothing. I had trouble starting my VT Acclaim auto. Turn key, nothing asked on here, no result. My son who worked at a dealer said turn the key so the buttons and dimple section is down when I put the key in. Did that, problem fixed. I thought the key was supposed to work either way. ???
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    Depends if u have the series 1 key reader or series 2, the series 2 has the full metal contact ring where the series 1 only has the 2 metal tabs which become faulty easier, which could explain wat just happend.
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    Super_Low 91's Avatar
    Super_Low 91 is offline ┌∩┐(◕_◕)┌∩┐
    Nimbus 2000
    Sep 2008
    Hogwarts
    so another words, one of the contacts on the ignition has a dodgy connection,, you can unclip it and check the wires,, by the sounds of it one of the wires has come loose hence the key only working one way
    Signature Goes Here
    VT Acclaim Wagon
    Oct 2008
    Nimbus 2000
    Sep 2008
    Hogwarts
    As far as i know yes it should fit, i cant see any reason why not,, they the same size it would just be the wires on the back but that's nothing to major to fix if it needs changing
    Signature Goes Here
    wrx884's Avatar
    Mar 2006
    They either call it the key reader or the ignition ring but yep straight swap and slips over the ignition barrell, its all plug n play with 2 wires, a ground and the ignition globe.
  1. No Ignition Spark from ignition coil?????
    By Huddo001 in forum V8 Development and Modification
    Last Post: 14-04-2010, 06:54 AM
  2. VT Ignition
    By demenace47 in forum Electrical Wiring / Questions
    Last Post: 10-02-2009, 12:43 PM
  3. no ignition
    By darkangel in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-06-2008, 01:50 AM
  4. Ignition problem help needed, Ignition lead fallen out??
    By boourns in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-06-2008, 05:04 PM
  5. MSD ignition
    By AndyVKSSA in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-03-2008, 10:31 PM
