Results 1 to 7 of 7
Thread: How to remove nock sensors?
    ahmedomnnea is offline Ahmed.Iraq
    VX-II Excutive, 3.8 V6/A4
    May 2009
    Iraq
    Default How to remove nock sensors?
    Hi,
    I want to flush the cooling system in my VX V6, some posts here said that you need to remove the nock sensors to completely flush the system, How can I remove them? do I need to remove the exhaust first to get to them? or is there a way to do it without removing anything?
    thanks in advance.
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Don't remove the knock sensors, just use the old hose in the pipe method. Also remember to turn the heater on so that it can drain the fluid from there too.
    Ronald Reagan (1986)
    VT Acclaim Wagon
    Oct 2008
    acarmody, when you say "the old hose in the pipe method" is this to drain, or to flush the block? If it is to flush the block, be a very good idea not to mix the coolant with water before putting it in as the block retains about 6 liters of water even if the bottom hose is dropped. just tip 6 liters of coolant in after doing flush. don't forget to clean the overflow reservoir and put a 50/50 mix of coolant in it to the full mark. hope this helps
    VT Acclaim Wagon
    Oct 2008
    Ahmed, if you really need to remove the knock sensors, it would be good to put the car on ramps, even better to put it on a hoist. There are two knock sensors, one on each side of the block at the lower part near the engine mounts. each one has a metal shield over it. unbolt the shields, remove the knock sensor wires/plug (they oval, just squeeze the oval and pull gently) and unscrew the units (22mm socket, universal swivel and extension). when you refit them, some thread seal (loctite 242) on their threads will prevent leaks and stop them coming loose , tighten to 22nm. Don't over tighten as you will be buying new knock sensors. Shield bolts go up to 35nm. all the best.
    May 2009
    Iraq
    thans for the replys,
    first, whats the "old hose in the pipe method"?
    second, whats the nut size of the nock sensor?
    thanks again.
    VT Acclaim Wagon
    Oct 2008
    I am not too sure of "the old hose in the pipe" method. I think it means just flush the motor and heater core by putting a garden/water hose in the top radiator hose and dropping the bottom hose so water runs through the motor and heater core do the same for the radiator. This only works if you remove your thermostat first and turn your heater control to the hot position. I gave you the size of the knock sensor nut/socket in my last post, it is 22mm
    VX Berlina
    Apr 2007
    Thanks for answering graham7773, yep thats what I mean. If you do this right then it will get most of the coolant out. You will never get 100% of the coolant out no matter what you do.
  1. ve nock in front end
    By brizzo in forum VE Holden Commodore (2006 - ?)
    Last Post: 20-07-2010, 09:22 PM
  2. O2 Sensors
    By Tony. in forum V6 Development And Modification
    Last Post: 03-11-2008, 12:11 PM
  3. bad nock
    By blake0182 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-12-2007, 10:32 AM
  4. sensors
    By CAFA_TF in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-04-2005, 09:20 AM
  5. O2 sensors...
    By MY_95_VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-03-2005, 04:58 PM
