Results 1 to 14 of 14
Thread: Center Light + above door lights - Calais style
    VT S-Pack S2
    Sep 2010
    Default Center Light + above door lights - Calais style
    Hey, i have a VT S-Pack S2 just wondering if you can put in the lights above the back doors where the Jesus bar is like on the Calais etc. and also the center one where it has reading lights if it can be changed without added more wires etc
    feedback would be great!
    Hot-Rod's Avatar
    Hot-Rod is offline SuPaFlY -LiV3 Surviv3 Di3
    VX Commodore Series 2
    Sep 2005
    Oz
    sus,
    1 - the centre dome light is a straight swap with the calais centre dome light. Once it is screwed in it will work perfectly, plus the two extra spot lights on the dome light.
    2 - The rear courtesy lights that sit inbetween the roof handles on the rear. Wiring needs to be added for these to operate. I've recently completed this upgrade. It was a bit of a pain. I found a wire loom from a berlina. I cut off the wires that ran to the rear courtesy lights and spliced them into my current wiring harness for my executive. This is the only way the system will function correctly. Unfortunetly the berlina wiring harness has an extra wire, therefore won't work correctly if plugged in, in place of executive harness. The three wires are an orange with black line, white with blue line and a black with blue line i think. They are the same on the executive harness so it's a simple splice into these three wires to get the back courtesy lights working.
    MR_VX's Avatar
    MR_VX is offline Forced to be Fast
    VX S pac SII Raptorcharged
    Mar 2009
    Townsville, Qld
    ive swaped the standard interior light over to a calais one, it works but the reading lights are puts out stuff all light. i also put the rear lights in but didnt seem to come on when the doors are opened only on when switched on
    Check out my ride here >>>>My VX Raptor
    say NO to chev badges
    Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
    For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by MR_VX View Post
    I had the same result with the dome light.
    MY RIDE
    VT S-Pack S2
    Sep 2010
    Thanx heaps for the reply's might just leave the rear ones but get the center one
    cheers again!
    VT Executive
    Aug 2010
    Newborough
    I am in the process of replacing all of my lights with LED/Xenon
    Replace the globe in the centre roof light with an LED panel and you get bright WHITE light in the cabin
    VT Executive
    Aug 2010
    Newborough
    Mick1988's Avatar
    Mick1988 is offline W.A. Cruise Moderator
    Too many to list......
    Apr 2008
    Perth, Western Australia
    The reason that they don't work when swapped over is because the looms are wired differently. The pins on the connectors of the two different lights are actually in a different order. However the plugs at the other end of the loom near the drivers chair are wired the same so it's just direct plug and play to swap the loom.
    I'm in the process of rebuilding a VT wagon for my business and I'm using the interior from a VT Olympic edition wagon which has a MID level BCM. I checked the wiring near the drivers chair and the purple wire already exists in the loom meaning that with plug and play you should be able to directly plug the loom in and away you go. I'm hoping my other VT (also with a MID level BCM because it's fitted with traction control and cruise control) has the wiring there too so it all works properly.
    Not sure about LOW level BCMs though but I'm kinda thinking that since Execs have the wires for power windows already in them to the pillars that it would most likely be there too.
    VX2 Executive Sedan - 3.8L Auto (for now)
    VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)
    VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
    Hot-Rod's Avatar
    Sep 2005
    Oz
    Mick,
    Thats the exact problem I had. Was missing the purple 5th wire. Executive roof harness only had four wires (low BCM). When I plugged in the berlina harness to the executive floor clip/wire i noticed there was no 5th wire on the other side. The dome and rear lights still worked but only with door open and close. They didn't work when buttons pressed. If someone knows which wires could be rearranged or spliced to get the full function, then this could help people updating their executive povo pack interior lights to the berlina/calais interior lights without to much trouble.
    Hot-Rod's Avatar
    Sep 2005
    Oz
    Ricky,
    What modifications do you need to do to get the LEDs to work in the dome.?
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    Quote Originally Posted by Mick1988 View Post
    so if i fine a vx berlina/calais roof wiring harness i can just plug it in and all the interior lights will work in my vx s2 s pac?
    where abouts is this plug located?
    Hot-Rod's Avatar
    Sep 2005
    Oz
    MR_VX,
    it will not work correctly on your vehicle unless you have a Mid level BCM. So if you have cruise control or similar you may have the 5th wire (purple) for the berlina/calais roof harness to work. The plug is located on the drivers side pillar next to the floor. Remove the side plastic moulds, as well as the floor mould that runs from the front to the rear seat. Then you will be able to see the plug and wires coming down from the roof. If you have 5 wires joining your plug from the floor then it should work for you. But if yours is the same as mine you will only have 4 wires in the plug on both sides which won't work with berlina/calais roof harness.
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    Quote Originally Posted by Hot-Rod View Post
    MR_VX,
    arr righto thanks for that info. mines S pac so i have cruise control. is there away to tell if the BCM is a low-mid-high by looking at it? i have no idea even where it is located lol
    VT S-Pack S2
    Sep 2010
    Thanx for all the info, great stuff
  1. [SA] vt/vx centre lights with map light and.... calais courtesy lights wiring/set up
    By callum_88 in forum Parts And Other Items For Sale
    Last Post: 11-05-2009, 07:58 PM
  2. Need Door Courtesy Lights for VR Calais
    By hingo1983 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-12-2006, 05:21 PM
  3. Replies: 3
    Last Post: 26-10-2006, 05:43 PM
  4. Tail lights, HSV Calais style
    By twillcy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2005, 09:46 PM
