Results 1 to 5 of 5
Thread: Help error 48
    Commodore, VT S 97
    Jul 2005
    Queensland
    Default Help error 48
    I had to replace starter motor today because it starting smoking, bad habit, now when it try to start my car it turns over fast but dosen;t seem to fire, it takes 3 or 4 tries, any help? shows error 48 when checked
    VX Executive S2
    May 2006
    Frankston South Vic
    code 48 is Cam angle sensor. hopefully you have just knocked a connector loose
    are you sure it isn't code 47 crank angle sensor? a lot more common
    Commodore, VT S 97
    Jul 2005
    Queensland
    Definately 48, and 92, it was done by auto elect (no choice when your stuck in a car park) but will call them in morning to get them to check it
    VX Executive S2
    May 2006
    Frankston South Vic
    Commodore, VT S 97
    Jul 2005
    Queensland
    done some research and found out it may be the key, one of the screws fell out which appartly is the earth to the transponder? put it back in, car started fine, reset the fault codes and restarted, no faults, YET ?
  1. vx berlina traction and engine light come on intermittently/// error code error wtf
    By glennis in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-05-2010, 07:55 PM
  2. MSN error
    By S2_VR_ in forum The LAN Lounge
    Last Post: 09-09-2009, 12:39 AM
  3. E-99 Error
    By mrvx2 in forum Car Audio
    Last Post: 05-05-2009, 11:43 PM
  4. ABS error log
    By kopper69 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-04-2007, 10:12 PM
  5. error, error !!
    By dahlyla in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-08-2005, 07:57 PM
