Results 1 to 5 of 5
Thread: possible overheat
    1998 vt commodore
    Jul 2010
    nsw
    Default possible overheat
    hi normally my vt temp sits at 89 but yesterday rose to 104/105 in traffic jam got out of it and it now sits at 92 to 95 no oil in water how do i check the cap to see if its faulty also overflow is half full but radiator fluid is just visible should i fill the radiator or what as only had the vt for 3months and never had this problem b4
    VT Acclaim Wagon
    Oct 2008
    If your radiator cap doesn't look good, replace it on suspicion. Not expensive. As for slightly low coolant in radiator, definitely top it up. could be the cap sucking a bit of air but if you are worried, get a pressure test done on your cooling system. If you're really worried, get a compression test done on the cylinders as well. Water temp can go well over 100 without it being any concern as boiling point of good coolant, 50/50 mix is around 129c. If all is well, you can run the engine a bit cooler by installing an 82c thermostat. A few of the blokes on here do that.
    1998 vt commodore
    Jul 2010
    nsw
    ok am on my way to supercheap shortly get coolant and cap cant do thermostat as all my tools r at my house 400k's away so hopefully will get me home tomoz and get it done... when i topup the radiator do i need to bleed it at all or just top n go as i wont be doing anything else except getting coolant n cap
    VT Acclaim Wagon
    Oct 2008
    Would be better to bleed it. Also, if you can, use a coke bottle with the base cut off and enough insulation tape wrapped around the neck to make it a neat fit in the radiator neck (I am guessing you don't have the Holden tool for filling the radiator). Open the bleed valve so a little air/coolant starts to come out of it then pour coolant mix in slowly until no air is coming out of the bleed valve and radiator is full. Close valve, job done. Keep new tool for the next time.
    1998 vt commodore
    Jul 2010
    nsw
    quick last ???? but where is the bleed valve
  1. VX Random 3 monthly overheat
    By G200Sleepr in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-07-2009, 11:10 PM
  2. Best Oil after Overheat
    By Promotec in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-03-2009, 06:28 PM
  3. VR Aircon Making Car Overheat
    By ViN3Y in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-10-2008, 03:00 PM
  4. engine overheat
    By doggie458 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-02-2007, 10:31 PM
  5. minior overheat now and then
    By SlyVR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-03-2006, 07:18 PM
