hey ppl, a cpple of weeks ago i did a plug n lead change to my 5.0 and a few days later it started idding a lill off but only when it warm..
i rechecked the timming, put it at 10degrees btdc its a lill smoother but still jumps at idle.. only a lill bit tho, enough to annoy..
i ran an code check n it came up wit rich o'2 sensor?
could that be the reason?
i was thinking maybe cracked plug or dodgey lead?
any ideas would be great.
thanks
VR CLUBSPORT WAGONyes a clubsport wagon....
LIVE THE DREAM
Hi hq,
Had what sounds like the same issue. The idle sounds rough and the tacho needle jumps when it is rough?
Mine turned out to be a burned out lead. Hope that helps.
Jez.
i just done the leads, so surely not but ya never know, i checked all the pugs 2day n they where fine the plugs are NGK BPR6EF n the gaps are 25tho, no cracks on them. all at 25...
what plugs n leads do you run on yours?
LIVE THE DREAM
Plug gap should be 40 thou.
any1 agree on this?
im well confussed now...
LIVE THE DREAM
i will sus 2moro n let ya know! hope this works! cant wait to have it running properly again!
LIVE THE DREAM
na made it worse!!!! now im defiently thinking it must be a lead!
its at my mechanics now to get my tailshaft rebuilt n new booster so they're gonna look at it for me! cant be bothered nemore! had enough!
LIVE THE DREAM
traced it back to a dodgey coil and foul'd plug! thank F$%# thats over!
LIVE THE DREAM
