Results 1 to 8 of 8
Thread: Noise that i thought was pulley noise can't be ??????
    vx lumina
    Sep 2010
    adelaide
    Angry Noise that i thought was pulley noise can't be ??????
    Hi ALL,
    Please help i have a vx lumina was making what sounded like pulley noise. so i went and replaced all three idler pulleys but noise still there i have no idea were the noise is coming from very frustrating dont no what else to look at can some one please give me some advice on what the hell it could be because it is doing my head in now !!
    many thanks in advance
    chris oo
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    The belt itself can make a noise similar to a worn pulley. Spraying some silicone spray or WD 40 onto the belt while the engine is running will help for a short time but the noise will probably return.
    MY RIDE
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    Could be the water pump bearing, did you give it a spin when you had the drive belt off?
    VX Executive V6
    Jan 2010
    im with 'accentstencil' same thing that happened to me lucky i was there when the machanic did it or else i rkn he would of charged me for a pully and the belt
    jakbob's Avatar
    jakbob is offline Lighten up.
    VX SS, VC L, VK Vacationer
    Dec 2008
    Like Pablo said, take the belt off and start the engine for a short period. This way you can be absolutely sure if it is a belt/pulley/belt driven accessory issue. If it is it could be the bearings in your water pump, alternator etc. I had the bearings in my alternator go once. Luckily I had a spare one on hand.
    Four commodores and counting.
    vx lumina
    Sep 2010
    adelaide
    ok cheers guys i will repace it and get back to let ya know how i went thanks for your advice.
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    Turn your air con on and have another listen. If the noise stops with your air con on then the bearing on your air con clutch is shot. You can change it without letting the gas go.
    Dec 2005
    Default Same problem
    I think you've isolated my problem. I've got a squealing noise with the aircon off but goes when I turn the aircon on. I can't figure out why. Could you tell me how to change the clutch bearing on the compressor.
    It's on a Gen 3 VT Calais.
    Cheers,
    Glynn
  1. Pulley noise!!!
    By chris oo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-09-2010, 11:31 AM
  2. rattling pulley engine noise when idleing
    By Rider5 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-05-2009, 06:54 PM
  3. New A/C idler pulley making noise
    By aceventura in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-02-2009, 09:30 PM
  4. Vr commodore pulley noise
    By jasman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-02-2007, 03:29 PM
  5. VT V8 Gen3 noise near top pulley and radiator hose
    By bails in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-08-2006, 06:40 PM
