Results 1 to 8 of 8
Thread: opinions on.. at least 50% loss of power and missing/rough idle/shuddering
    callum_88's Avatar
    callum_88 is offline Donating Member
    VT Exec 5 spd/ VZ SS 6 spd 6ltr
    Nov 2008
    Salisbury Downs, SA
    Thumbs down opinions on.. at least 50% loss of power and missing/rough idle/shuddering
    my VT is a v6 5 speed for information's sake. ever since a few days ago when i dropped down to first going round a corner (wasn't going fast and wasn't trying to burnouts or whatever) revved the engine a bit, did a little bit of a squeak with the wheel, didn't think much of it. pulled over to drop off a mate then when i went to take off it would shudder, miss and carry on and id have to rev the engine quite considerably to get her going without stalling while engaging the clutch.
    last night had replaced plugs and checked leads which seemed to be ok, coil packs had a consistent ohm rating. battery is about 2-3 months old. fuel filter isn't that old.
    exhaust chugs a bit when taking foot off accelerator, but had done that before but not as severe, rough as hell idle, also the missing has been evident before this but it had been rare and when the motor is under stress.
    have checked for error codes and there is none. seems to be missing in one or two particular cylinders. and seems to be the worst when the motor is more under stress.
    going to replace the leads anyway and see if it makes a difference with a mates coil pack.
    thought id ask before going to a mechanic and kicking myself for missing something stupid and saving a bit of cash.
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    jiggle every electrical connector/fuse/relay/length of wiring in your bay with the car running - see if you can find something loose/broken. Sounds to me like something simple has just gotten a bit dislodged/loosened.. which is usually the hardest to diagnose
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Try the vacuum hose underneath the throttle body, comes off all the time and causes the car to run like shit. If it is that, put a small hose clamp or something on it to make sure it stays there.
    Ronald Reagan (1986)
    VX S series II
    Sep 2010
    I saw another thread were a guy had an auto with the same problem,Cant find it though.
    Pretty sure it was a break in 1 of the leads or a cracked plug from it being over tightened.
    I've got a very similar problem with my VX-Spak.Going to replace the plugs and leads to see if that works.
    callum_88's Avatar
    Nov 2008
    Salisbury Downs, SA
    changed leads, put in some injector cleaner for the hell of it to see if it may fix the problem, still running rough as
    had a look around and checked connections everywhere. nothing seems to be loose or anything.
    will try and change the coil pack soon
    callum_88's Avatar
    Nov 2008
    Salisbury Downs, SA
    Vy 5.7
    Nov 2006
    callum_88's Avatar
    Nov 2008
    Salisbury Downs, SA
    50 bucks off a mate, but they go for around that on eBay, prob a bit more in shops
LinkBacks (?)
  1. 27-11-2010, 03:48 PM
  1. Rough idle, Rough take off and rough stop.
    By Niggadore in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-06-2010, 05:49 PM
  2. VP Fault Code 13, Car shuddering and Vibrating at idle
    By FrangaVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-06-2010, 01:39 PM
  3. WH STATO L67 - Rough idle, power loss, surging. ANY IDEAS ??
    By fatbats in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-05-2010, 01:50 PM
  4. Engine Overheated / Very rough Idle / no power
    By Louieg in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-02-2010, 04:16 PM
  5. vt 5ltr huge power loss down low nd idle urgent help needed
    By GEEUUP in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-12-2006, 06:32 AM
