Results 1 to 9 of 9
Thread: Throttle body conversion?
    VX Exec M5
    Alien Invasion 2 Champion! Gyro Ball Champion!
    Apr 2010
    Melbourne, Bundoora
    Default Throttle body conversion?
    Hey guys.
    How hard would it be to adapt a 90 mm throttle body from an LS1
    to fit an ecotec? And would it be worth the effort?
    Thanks in advance
    None of us are as cruel as All of us. - Anonymous
    VT S2 LS1 -VX S2 SS LS1
    Feb 2010
    IPSWICH
    all things are possible. the first thing you gotta figure out is throttle linkage setup. fitting the throttle body should be simple enough. if the bolt holes dont line up(which they wont) just make an adapter plate up. bolt the adapter plate to the manifold then the throttle body to the adapter plate. bit of friggin around but it could be done
    A pessimist is a man who thinks all woman are bad. An optimist is a man who hopes they are
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Not really much point though is there, the entrance to the Plenum chamber would simply be the next restriction.
    Ronald Reagan (1986)
    VX Exec M5
    Apr 2010
    Melbourne, Bundoora
    Hadn't thought of that ... yeah unless I actually modified the plenum chamber entrance as well. That would be a huge pain in the arse.
    Thanks for the input guys.
    I might give it a go down the track when I've got some more time.
    Feb 2010
    IPSWICH
    Quote Originally Posted by Kieran263 View Post
    wouldnt be to hard if your handy with a die grinder
    just buy another manifold & use it as an experiment would be the go,that way your cars not off the road
    VX Exec M5
    Apr 2010
    Melbourne, Bundoora
    Haha, well I did get an A+ in Yr 10 metal work XD. Good idea with the practice
    manifold, might head to a wrecker and see how cheap I can score one
    VX Berlina
    Apr 2007
    I say go for it mate, it will be quite a bit of work but stick to it. You will have to get the car tuned to read what the hell the TPS is saying, so you might as well get a LS1 MAF as well and even upgrade the air pipe from the air box to the TB.
    VX Exec M5
    Apr 2010
    Melbourne, Bundoora
    I like a challenge, and its because its a bit different. I figure a 90mm throttle body is (depending on what sort you get) is like $250-$350. The biggest ecotec throttle body is
    a bored out 70mm one for like $250 anyway. Defs get the tuning done, Mace do 84mm MAF's so I'd probs mate up one of them. Just gotta get some money lined up
    VX Berlina
    Apr 2007
    Ah the fun part.
LinkBacks (?)
  1. [SA] 304 manifold injectors injector rail and throttle body , 70mm throttle body suit v8
    By slywgn1 in forum Parts And Other Items For Sale
    Last Post: 10-06-2010, 08:42 PM
  2. Throttle body
    By VZ06 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 01-09-2009, 07:03 PM
  3. Throttle Body 4 L67
    By VS CALAIS in forum V6 Development And Modification
    Last Post: 30-06-2006, 10:13 PM
  4. throttle body conversion
    By megee83 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 02-05-2006, 11:21 PM
  5. v8 throttle body
    By Rumbl in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-03-2005, 11:37 PM
