Page 1 of 2 12 LastLast
Results 1 to 25 of 38
Thread: Manual fuel calibration for vt vx finally revealed for cars with 1 window dash
    vx
    Aug 2009
    Default Manual fuel calibration for vt vx finally revealed for cars with 1 window dash
    hi again guys.. we all know that the fuel calibration for some cars vt and vx with 3 window dash is listed in the owners manual but for the 1 window dash is unknown and its not listed in the owner manual it can be calibrated if u go to the sharks and use tech2. now its revealed all u have to do is( hold down the mode and the left keep holding until the screen dash change now press mode until u see serial. now the correct fuel calibration number u should see is off80off . if its different from it u should press mode after serial till u fing the fuel calibration table u have to change these numbers by using the arrows right and left until u reached (off8off) thats what holden dnt want u to know. tested on vt vx.
    99 VT Sedan
    Feb 2010
    Quote Originally Posted by rocket0000 View Post
    Do you hold these buttons befor starting the engine??
    vx
    Aug 2009
    before or after mate. doesnt matter the only thing u wanna make sure of is to check whether the car have the correct fuel
    vx
    Aug 2009
    after u do this ur distance to empty will be very accurate no playing up unless there is another existing problem...... other thing if u guys wanna check that ur distance to empty is very accurate u have to do same procedure but this time keep pressing mode until u see (o empty and three numbers) like that ( o empty 350) now write down this number and exist and go back check ur empty to disnatce. now IF THE READING IS DIFFERENT FROM 350 LIKE 250 OR..... THAT MEANS UR DISTNACE TO EMPTY IS PLAYING UP ITS NOT ACCURATE.
    99 VT Sedan
    Feb 2010
    Thanks how did you find out all this uesful info????
    vx
    Aug 2009
    mate i worship something called vx commodore and since i bought one i was exploring and exploring and after paying heaps of money going to holden and coming and fixing and asking i came up with this. believe me if i wanna type how did i know all that I'll spent hours.
    this information bout clearing history codes and fuel number calibration is very accurate for whom who want to believers and unbelievers...
    99 VT Sedan
    Feb 2010
    I belive you.....Thankyou..
    Do you have any more info??
    Vt-Brrrlina is offline vp bt1 gts replica
    vp bt1 5.0ltr full GTS kit
    May 2006
    Perth, Western Aust
    doesnt work,.. closest i got was Fd80aD so no idea what that does.... or if its corect
    ahmedomnnea is offline Ahmed.Iraq
    VX-II Excutive, 3.8 V6/A4
    May 2009
    Iraq
    I have a VX with one screen on the dash and it seems impossible to get that value you've mentioned.
    vx
    Aug 2009
    mate i test this on my car it works like magic . the number u should get is FF80FF
    May 2006
    Perth, Western Aust
    hmm well thats a bit different to off80off..... so we looking for FF80FF... ill try again and have a looksee
    May 2009
    Iraq
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    Interesting none the lest, im curious 2 wat all the other things that r listed r?? i saw a SPD (assuming speed??) with 24 in the display and a lil O in the right hand corner?
    tho my current value is FFFFFF
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    VXII
    Nov 2009
    I don't follow. What fuel related value does this calibrate?
    Tank size?
    Sender part number?
    Fuel delivery map?
  15. #15
    DLFHUB666's Avatar
    DLFHUB666 is offline Got Milk ???
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    i cant get the value you have stated. I didnt write down what it was on to start with can anybody help me with that??? does it even matter??? because there is a big range that it could be set too.
    Take it easy...But do take it...
    Do not argue with an IDIOT.
    He will just drag you down to his level an beat you with experience
    Some people take me the wrong way, Like smacking up Marijunna.
  16. #16
    VX lumina
    Jul 2008
    SE Melb
    the highest value i was able to get was also FEFF.FE
    do i need to have a full tank of petrol to attempt this?
  17. #17
    VX Evecutive wagon
    Jun 2010
    Alexandra Hills
    vx
    Aug 2009
    guys calm down all u have to do is let number 80 be between ff and ff like this ff80ff its not bout to get the highest figure. all u have to do is to get number 80 in between. now fd80fe is correct now actually some numbers might be unclear for the quick update they get. the most important think is to check distance to empty and compare it with the figure in the hidden extra options.
  19. #19
    DLFHUB666's Avatar
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    so now its fd80fe. what is it ff80ff or fd80fe
  20. #20
    vx
    Aug 2009
  21. #21
    vx
    Aug 2009
  22. #22
    vx
    Aug 2009
  23. #23
    DLFHUB666's Avatar
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    so now it is fd80ff.
    so what you are sayin is as long as 80 is in the middle it dosent matter what the other numbers / letters are ???
    How come your 1 isnt ff80ff ????
  24. #24
    vx
    Aug 2009
  25. #25
    DLFHUB666's Avatar
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    So if fd80ff is the default setting. what is the number we are chasing ???
  1. Replies: 28
    Last Post: 19-08-2010, 09:05 PM
  2. Dash Calibration
    By Chris92 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 27-07-2010, 09:18 PM
  3. vt dash calibration needed
    By dcjacko in forum Electrical Wiring / Questions
    Last Post: 08-10-2009, 07:27 PM
  4. Replies: 19
    Last Post: 17-11-2008, 07:25 PM
  5. vy fuel calibration help? :(
    By cpbait in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-07-2008, 05:19 PM
