Results 1 to 4 of 4
Thread: vx ss irs camber kits
    vl calais 355 turbo
    Sep 2010
    campbelltown
    Default vx ss irs camber kits
    need the do's and don'ts for the rear of my ss.pedders says to hard to do at home.k mac says can be done with there kit as it comes with bush extraction tool.pedders want 600 plus for kit and labour.k mac want 295 and do your self all is needed is a wheel alignment.what do you think
    DLFHUB666's Avatar
    DLFHUB666 is offline Got Milk ???
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    i have heard that it is a bitch to put a camber kit in. but with a $300 saving i would give it a go myself for sure .
    Take it easy...But do take it...
    Do not argue with an IDIOT.
    He will just drag you down to his level an beat you with experience
    Some people take me the wrong way, Like smacking up Marijunna.
    VX 'S' S1
    Apr 2005
    South East,Victoria
    It can be a pain mainly because when removing the bolt from the outer bush it hits the chassis and the rear sub frame has to be unbolted and dropped about 100 mm to pull the old bolt out . Also the rear half of the exhaust has to be removed . When i got my 4 point kit fitted the guy had it for the best part of the day . It cost $350 fitted including wheel alignment , can't remember what brand it was but it has blue bushes
    VL Berlina
    Dec 2009
    My experience with K-Mac kits is that they can usually be fitted by a reasonably thoughtful car owner.
    Some kits, especially strut top camber kits, will require a spring compressor (Super Cheap Auto sells a decent enough one for about $40), but otherwise it's just ordinary hand tools.
    There's no doubt, too, that the K-Mac kit will be a better thought-out arrangement than most others. There will be appropriate fittings and design features in place to give what's needed in the suspension units involved.
    When there's a bush that can adjust camber or caster, there are hardened teeth on the ends of the nickel-chromed inner bushes, these also having spirals for grease to go into so the bushes are lubricated. The teeth bite into the rail or suspension unit and won't move if done up properly, so the settings are maintained despite extreme use. Extra-length nuts with serious spring washers are supplied with these kits as well.
    There's never enough praise for the K-Mac designs, and they're available for so many cars. A very wide range.
  1. Camber Kits
    By garywg in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-05-2009, 04:19 PM
  2. Camber Kits - Who Has One
    By sweefu in forum General
    Last Post: 24-03-2009, 11:18 AM
  3. Camber kits
    By emmtee83 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-04-2006, 08:52 AM
  4. camber kits
    By totality in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-03-2006, 06:38 PM
  5. camber kits
    Last Post: 18-01-2006, 05:52 PM
