Results 1 to 8 of 8
Thread: Radio Fuse Keeps Blowing!!!
    boohsv is offline boohsv
    vt commodore Berlina
    May 2009
    Default Radio Fuse Keeps Blowing!!!
    Can someone please help?? My radio Fuse keeps blowing,,it just happened one day out of the blue. Ive disconnected the radio and speakers but it still blew the fuse. I went out and bought myself a 12 volt test light,,went though all the fuses in the fuse box and the light dropped out on pulling out the MAIN F/L 60A FUSE.What does this mean and how can i fix it myself?
    VT S2 LS1 -VX S2 SS LS1
    Feb 2010
    IPSWICH
    check all the earth connections
    A pessimist is a man who thinks all woman are bad. An optimist is a man who hopes they are
    May 2009
    Sorry dont know much about engines, where do i find the earth connections?
    1998 vt commodore
    Jul 2010
    nsw
    clean the earth lead on ya battery there is also an earth wire of ya water pump and 1 on ya drivers side strut housing try those clean them good worked for me today at tafe had stray voltage cleaned them up good and fixed my problem
    May 2009
    Thanks for the reply.Im guessing the earth is the ground connections? Where exactly do i find these connections and how do clean?Thanks.
    1998 vt commodore
    Jul 2010
    nsw
    EMERY PAPER clean ya battery terminals too the earth wire is the ground with out it nothing will work or wont work properly i will go check the color of the wires if i can find my torch n let ya know
    May 2009
    My terminals look ok and my negative is new so i doubt it could be that. I have no idea where else to look.cheers
    VX Lumina V6
    Feb 2010
    When a fuse keeps blowing it means the power lead is shorting out to earth somewhere in that circuit. I'd suggest perhaps the active wire has rubbed through the insulation and you have a bare wire touching the bodywork. Unless your experienced in chasing electrical fauls, it looks like a job for an auto electrician
  1. Car keeps blowing Radio Fuse
    By FstStig in forum Electrical Wiring / Questions
    Last Post: 06-08-2010, 07:53 PM
  2. Blowing fuse..
    By Lloydy1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-11-2009, 09:16 AM
  3. fuse keeps blowing
    By to_easy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-01-2009, 08:42 PM
  4. Blowing fuse VS V6
    By TrustNo1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-07-2008, 04:48 PM
  5. A/C blowing fuse VP
    By twasm6 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-12-2006, 07:29 PM
