Results 1 to 7 of 7
Thread: Pod Filter and Manifold Air Temperature Sensor
    VE MY09.5 SV6 5sp Auto
    Dec 2009
    Default Pod Filter and Manifold Air Temperature Sensor
    I've installed a pod filter on my VT 3.8L V6, I was told it would help keep the stupid thing cool and it would help improve on fuel economy. either way i tap the accelerator and the stupid car takes off like theres no tomorrow?
    Just needed to know, how can I get the MAT sensor to work if I've got a pod filter? I can't place a lid over the filter, it wont fit. The bonnet holds the pod filter down (doesnt do any damage to it). How can I get the sensor to get a reading? I keep getting error code 23
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Puth the temp sensor in the pipe as close to the throttle body as you can.
    Visit my Facebook page
    VXII
    Nov 2009
    I think you'll find that there's a fault with the sensor or wiring.
    As long as it's plugged into the wiring harness, the IAT (intake air temperature) sensor will still work, even if it's not pushed inside the intake system. it just won't read accurately as it's not sensing the intake air. Without having it set up properly, you will negate any claimed performance benefits by measuring the hotter engine bay air.
    Remove the pod filter and reassemble it back to standard. Don't waste any more money.
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    I don't see any reason why you can't just cable tie the sensor as close to the pod as you can, that's more or less how the standard panel setup is. But as Not_An_Abba_fan said it's probably better if it's close to the throttle body.
    VR_Acclaim is offline Banned
    Vr acclaim
    Jun 2010
    U can get the metal pod adaptor from auto barn n they have hole for the mat sensor
    VX Acclaim sc L67
    Mar 2009
    nth qld
    you want that temp sender as close to the filter as possible, so its getting the air at its coolest. Just plumb it into your intake pipe just behind the pod. If the sensor is near the Throttle body the air will have warmed up a little by than. Because the exh is under the pipe and the air itself will cause friction inside the pipe which = heat.
    VY SII HBD Calais L67
    Dec 2006
    The Intake air temp sensor must be enclosed. Either in side the pod box which you should be running (exposed pods in an engine bay defeat the purpose of a cold air intake) or if you don't have the pod enclosed, like the others said the sensor needs to be in the air stream as close to the initial source of air intake. Best spot is directly after the filter in the intake pipe as this replicates the factory set up as closely as possible
    VYII Calais L67
  1. Coolant temperature Sensor
    By Trayner in forum General
    Last Post: 27-06-2010, 11:08 PM
  2. Temperature sensor 92017805
    By Aus78Formula in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-11-2008, 03:17 PM
  3. Temperature gauge or sensor
    By vnbelina in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-10-2006, 06:10 PM
  4. Coolant temperature Sensor
    By cacaman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-07-2006, 11:48 AM
  5. location of temperature sensor - VB
    By forest in forum Electrical Wiring / Questions
    Last Post: 15-01-2006, 10:06 PM
