Dose anybody know if the rear door trims have a imprint where the rear switch for power windows go's so it can be cut out or dose anybody have a template to do it as I don't want to replace the door trims
No imprint. All you can do is check out a car with the switches and get a rough idea of where they go. I would install the switch into a piece of cardboard and get a good fit, then remove the switch from the cardboard and use the cardboard as a template. That's what I did and it turned out good.
MY RIDE
You can find door trims dirt cheap....I'd definetly be grabbing a set and swapping the fabric inserts over to match your interior.
Atleast that way the switches are easy to install and you won't have holes left from the window winders
Hot Red VX SS - 5.7L Gen3, Pacemaker tri-y's, Dual 2.5", 6 Speed, 3.47 LSD, 18" HSV Clubsport wheels
Stereo - Alpine 9887, JL 300/2, Audison LRx1.1k, Image Dynamics IDMAX 12", Focal 165VR's + Dynamat
