Results 1 to 4 of 4
Thread: brake fluid top up?
    VX Executive Series II
    Oct 2008
    Western Australia
    Question brake fluid top up?
    Hey All, just wondering how often should you expect to have to top up your brake fluid? I had slotters fitted a year and a half ago and the quote said they replaced the fluid, would you expect to be needing to top up the brake fluid reservoir in this time? I have done around 40000 k's since then and upon checking the reservoir yesterday, I noticed it needed fluid...I haven't noticed any leaks from under the car and I figured a year and a half isn't too bad as my brakes do get a fair workout most of the time, but a mate of mine suggests that there could be an issue, although my gregory's manual says to check the fluid levels every 400k and top up as required. kinda confused here so advice would be appreciated...
    My Ride: 02 VX Exec II, 192.2 rwhp v6, black
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by VXdarkmagic View Post
    As the pads wear it cases the pistons in the callipers to come out further, therefore more fluid needs to fill this space, so the level drops. I hope this makes sense to you.
    MY RIDE
    Oct 2008
    Western Australia
    Quote Originally Posted by accentstencil View Post
    cheers for the reply, yeah that makes sense and my pads are probably fairly worn at the front so shouldn't really be a problem then? my main point is, is a year and a half too soon to be expecting to have to top up the fluid levels in the reservoir?
    VT Acclaim Wagon
    Oct 2008
    If you are topping it up, you might as well change it while you are there. Getting close to 2 years which is when it should be changed anyway.
  1. brake fluid
    By mrvdv85 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-10-2009, 04:13 PM
  2. What brake fluid for VH ?
    By Secki in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 25-08-2009, 04:24 PM
  3. best brake fluid?
    By pow3rslave in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-11-2008, 07:52 PM
  4. what brake fluid do i use?
    By ShIbBy_industries in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-06-2008, 09:14 PM
  5. Brake Fluid and Auto Trans Fluid.
    By Melchior3 in forum General
    Last Post: 20-02-2006, 11:49 AM
Tags for this Thread
