Results 1 to 7 of 7
Thread: Changing Manifold Gasket
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Default Changing Manifold Gasket
    OK , I have to put a new intake manifold gasket on my VX V6 . Just wanted to know what price will i be looking at for one and what brand should i go for or are they all much the same . Also what other parts will i need ? I was told something about coolant supply tubes and replacing the O rings , do these come with the gasket set or do you have to buy them seperately ?
    Ive done a few manifolds over the years in V8 s and 6 ,s but not a V6 ( yet )
    Thanks in advance Dave
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    I bought a set from Bursons about a year ago for a VN V6. Just asked for intake manifold gaskets and walked out with a set. Intake manifold gaskets, valley seals, throttle body and plenum gaskets and an o-ring. The o-ring wasnt needed for the S2 motor but the lot was around $50 give or take.
    My (ex)Ride
    Quote Originally Posted by ari666 View Post
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Ok thanks for that . Might give it a go next weekend
    supercharged vt II acclaim
    Sep 2009
    goldcoast
    $50? bloody bargain..
    i were guna suggest mace's store (where i got mine from a few weeks ago) there the metal ones and are re-usable and last forever, but there $110 for valley gaskets and rubber end bits .. which was the cheapest i could find anywhere for a vt.... and postage was next day delivery..
    the o-rings- i had to replace them on the coolant pipes as mine leaked with re-using the old ones. just got a box of assorted ones from supercheap for $10 and was enough to do what ever ones needed replacing
    Quote Originally Posted by chargedvx6 View Post
    I meant what I said and said what I meant so if you mean to say I said what you think I meant and it wasn't actually what I meant then that means you mistook what I originally said and meant to be wrong when in fact it isn't..
    my supercharged vt acclaim
    http://forums.justcommodores.com.au/...claim-l67.html
    VX 'S' S1
    Apr 2005
    South East,Victoria
    I just bought the intake gasket set for $80 from Autobarn . I wet to supercheap to find the fuel line quick release tool cos autobarn didn't have them in stock and the guy at supercheap said you can only get them from Holdens spare parts . Then he proceded to open some boxes of fuel filters to see if they came with the filter .Told him that i needed the tool for the fuel lines in the engine bay again he said you cant buy them so as i was walking out i seen them hanging up for $15 a set . Don't you just love Super cheap lol
    I also done a compression test and they all came up at around 1200 kpa which i suppose is ok . Does anyone know what they should be ?
    MR_VX's Avatar
    MR_VX is offline Forced to be Fast
    VX S pac SII Raptorcharged
    Mar 2009
    Townsville, Qld
    how does one do a compression test on a vx? i wanna see what mines reading
    Check out my ride here >>>>My VX Raptor
    say NO to chev badges
    Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
    For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
    VX 'S' S1
    Apr 2005
    South East,Victoria
    First you need a compression tester , mine cost about 50 bucks . Then go for a drive to get the motor up to normal operating temp . Then pull out all the spark plugs , screw the tester into the spark plug hole and turn the motor over and watch the needle on the tester . It should reach the maximum compression after the motor turns over about 4 times . Repeat this on the other 5 cylinders . Make sure you write down the readings for each cylinder then compare the results. Just make sure you remove the relay from the fuel pump before you start . ( and keep some burn cream handy when you sizzle you fingers on the exhaust .)
  1. head gasket or intake manifold gasket? how to tell? bit of assistance
    By Go_Slow in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-02-2011, 04:26 PM
  2. Head Gasket? Inlet Manifold Gasket ? which one ?
    By Hydrobollox in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-04-2010, 08:11 PM
  3. Flange Gasket and Exhaust Manifold Gasket
    By mrvdv85 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-09-2009, 06:46 PM
  4. Changing manifold gasket on VH
    By VS_Wagon_Baby in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 24-12-2008, 09:37 PM
  5. changing inlet manifold gasket??
    By muney in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-08-2004, 09:17 AM
