is there a way to find out if my vx s2 has side airbags before I remove the door trim and wiring to install power windows.if I have side airbags will disconnecting Batt ,so the airbags done go off
it may have been an option - maybe check the VIN against the hand book - it may say how many air bags it has.
and 3 Dangerous non ABS VN's
Correct, there were no airbags in the doors / pillars
An easy way to tell if your car has them - On the C pillar exterior trim it will have SRS airbag silkscreened.
If its an executive chances are it only has a drivers airbag unless it was optioned up.
Hot Red VX SS - 5.7L Gen3, Pacemaker tri-y's, Dual 2.5", 6 Speed, 3.47 LSD, 18" HSV Clubsport wheels
Stereo - Alpine 9887, JL 300/2, Audison LRx1.1k, Image Dynamics IDMAX 12", Focal 165VR's + Dynamat
click the link below for production option codes fr the VX
http://www.phoenixmechanical.com.au/...tech_5_vx.html
A pessimist is a man who thinks all woman are bad. An optimist is a man who hopes they are
If it doesm it will have SRS Side Impact Airbag stamped in white writing on the black plastic panel between the two opening windows. If it doesn't already have power windows, the chances of it having side airbags are almost zero. The airbags are in the side of the seats anyway but either way you should disconnect your battery before touching ANY wiring.
VX2 Executive Sedan - 3.8L Auto (for now)VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
