Page 1 of 2 12 LastLast
Results 1 to 25 of 29
Thread: Rear Speaker/Door Card Issues *Help Needed*
    VX II S-Pack
    Aug 2010
    Victoria, Melbourne
    Default Rear Speaker/Door Card Issues *Help Needed*
    Hey guys, Had a person in the backseat for the first time yesterday and they told me they couldn't hear any sound from the rear speakers..
    After further investigation I saw that there is no bloody speakers in the parcel shelf and I couldn't hear/see anything in the rear doors, I guess the previous owner took them out the bastard..
    After reading Ozzie's "How To" Remove Door Card & Speaker Grill on VT-VX I took my door card off and surprisingly there was actually a rear speaker sitting in there..
    Here's a pic of the door card off:
    The speaker still in there:
    The wire still hooked up:
    The part number on the back:
    Does anyone know why this bloody thing won't work? I've unplugged/replugged the wires and that didn't fix it obv..
    VX SS 5.7
    Mar 2009
    North Adelaide
    Are both rear speakers not working or just the one?
    I'd be checking the wiring at the headunit. Also get a multimeter and measure the resistance of the speaker - it should be around 4ohms.
    Hot Red VX SS - 5.7L Gen3, Pacemaker tri-y's, Dual 2.5", 6 Speed, 3.47 LSD, 18" HSV Clubsport wheels
    Stereo - Alpine 9887, JL 300/2, Audison LRx1.1k, Image Dynamics IDMAX 12", Focal 165VR's + Dynamat
    VX II S-Pack
    Aug 2010
    Victoria, Melbourne
    Both read speakers are not working, also the speakers in the parcel shelf have been taken out.. I'll look at the head unit but what should I be looking for?
    VQ S2 304
    May 2009
    I have the same problem on my vt, although I noticed if you fiddle with the rubber casing that conceals the wiring going into the door from the b pillar area, it seems to cut in and out. Perhaps the wiring has worn away on the inside of the rubber? I haven't had a chance to check it out but its on my to-do list
    VX II S-Pack
    Aug 2010
    Victoria, Melbourne
    I'll have a fiddle with the wiring on the door as I can't get my headunit out because the previous owner didn't give me a PIN - I'll have to take it into holden to get that...
    VX SS 5.7
    Mar 2009
    North Adelaide
    You should be able to pull the headunit out - but just don't unplug it if you don't have the pin.
    You should be able to see if the wirings been messed with though.
    2002 VX II Acclaim
    Aug 2008
    stupid question, but have you checked your fader/balance controls? Maybe your speakers are faded all the way to the front, hence the silent rears..... Worth asking before you start pulling crap apart
    VX II S-Pack
    Aug 2010
    Victoria, Melbourne
    There are no fader options in a VX ... as far as I could find.
    Didn't risk fiddling with the headunit.. is there a possibility that the missing parcel shelf speakers may be in circuit with the rear door speakers and that's why they don't work?
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    Id test the speakers with the fronts 2 see if its the speakers themselves that r no good. If there were speakers in the parcel shelf at some stage the previous owner could have cut the wire in the pillar and tapped into that 2 run new wires 2 the rear shelf. i did this 4 a lil while b4 i put amps in and left my original speakers in the doors.
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    VX II S-Pack
    Aug 2010
    Victoria, Melbourne
    Quote Originally Posted by wrx884 View Post
    Hey mate, good idea about testing the speakers with the front. I'll give this a go tomorrow.
    Not sure about the tapping.. The original owner finally got back to me - he said he never noticed the rear speakers not working, he had 6x9s in the parcel shelf and a sub under the carpet of boot.
    VQ S2 304
    May 2009
    Quote Originally Posted by VX Appeal View Post
    There are fader options, push the volume buttom in and as soon as it shows "f" on the screen you can use the dial to go left or right and it will adjust the fader to front or rear....worth a shot
    wrx884's Avatar
    Mar 2006
    U could also check the wiring from the head unit and/or loom at the pilar 4 continuity with a DMM, if u hear nothing its been cut or has a break somwhere.
    VX II S-Pack
    Aug 2010
    Victoria, Melbourne
    Quote Originally Posted by alpha_au View Post
    Just checked this, if you press the volume knob once, it shows "TRE" - press it again it shows "BAS" - press it again it shows "BAL".
    If you hold down the volume knob, it shows "TRE" then back to normal clock - nice try but damn!
    I'm not too familiar with any of that, all I know how to do is check the connections with a multimeter lol.
    wrx884's Avatar
    Mar 2006
    Thats all u need man. set it on continuity (the 1 that buzzes wen u touch both ends 2gether) Basically it checks that theres no breaks in the circuit from point A 2 point B.
  15. #15
    VX 'S' S1
    Apr 2005
    South East,Victoria
    If he had 6x9s in the parcel shelf then i would say he has used the wires from the rear door speakers to run them . He may have cut them near the centre pillar and then run them under the carpet and then behind the rear seat
  16. #16
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    yeah man you have no rear speakers.. for some stupid reason they didnt come standard
  17. #17
    VX II S-Pack
    Aug 2010
    Victoria, Melbourne
    Alright mate I'll try this tomorrow - as well as putting them in the front door to test.
    Quote Originally Posted by Dayvo View Post
    So I would beable to see the wiring under the carpet?
    Quote Originally Posted by Cameron P View Post
    By rear speakers you mean the ones in the parcel shelf?
  18. #18
    wrx884's Avatar
    Mar 2006
    The parcel shelf r 4 the higher end models that r equiped with 8" subs thats y no speakers get put in the rear shelf as standard.
  19. #19
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
  20. #20
    VX II S-Pack
    Aug 2010
    Victoria, Melbourne
    Ah ok, so there would be no factory wiring in there? I guess it depends on how the previous owner wired them up.
  21. #21
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    i would forget about the door speakers and fit some some speakers to the parcel shelf
  22. #22
    VX II S-Pack
    Aug 2010
    Victoria, Melbourne
    Is there no way to have both?
  23. #23
    wrx884's Avatar
    Mar 2006
    not unless it had the subs there previously as they had an external amp 2 run the subs i believe.
    u could but u wouldnt gain or benifit anything from doing so.
  24. #24
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    btw the factory head unit restricts the speakers big time, just so you know! btw can someone tell me how to put a profile picture up? i have looked everywhere! dont wanna make a thread haha
  25. #25
    VX II S-Pack
    Aug 2010
    Victoria, Melbourne
    There's no benefit in making the door speakers work? Wouldn't it sound better?
    Can you recommend a setup? By the way, it has a "spacey spare tire" (really thin spare tire) which was put in to allow more room for the sub I assume.
    Click on Settings (Top Right of Screen) > Add Avatar
  1. "How To" Remove Door Card & Speaker Grill on VT-VX *Detailed*
    By Ozzie in forum Holden Commodore How-To's
    Last Post: 05-12-2011, 05:25 PM
  2. Removing Door Card & Speaker Grill VT-VX
    By Ozzie in forum General
    Last Post: 14-01-2011, 12:48 AM
  3. rear door speaker size?
    By BigDaz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-07-2006, 10:09 AM
  4. VT rear door speaker size??
    By BigDaz in forum Car Audio
    Last Post: 25-06-2006, 01:20 PM
  5. Rear Door Speaker
    By wanted7 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-03-2006, 12:04 PM
