Results 1 to 8 of 8
Thread: Quick VX headunit question
    VX II S-Pack
    Aug 2010
    Victoria, Melbourne
    Default Quick VX headunit question
    Hey guys, refer to this topic: Rear Speaker/Door Card Issues *Help Needed*
    I want to take the headunit out, check the wiring and put it back in without fuss.. But I've got a few questions before I do;
    - Will the alarm go off? If so how do I stop this?
    - If not, will it require a PIN when i put it back in? The previous owner didn't give me one.
    - Any other info that I need to know before I do this?
    I have instructions on how to take it out, but I need to know the above before I do.
    VQ S2 304
    May 2009
    Not sure about the alarm but I know you'll have to input your pin in when you connect it back up.
    VX Calais LS1, VS Calais L36
    Mar 2010
    You can get the PIN from Holden. They'll charge you for it though. $30 or something like that.
    You'll need it sooner or later anyway, if the battery goes flat you'll need it then.
    VX Pinoy Mafia
    Sep 2009
    PIN is reqd when you put back the radio.
    Alarm will not go off, unless you have an aftermarket alarm fitted.
    Holden will charge $XX if you need to retrieve your PIN from them but if you know where the car was originally bought you can ring the dealership and they can give it to you for free.
    If you are just replacing your Headunit, all you need is 2 wiring harness (eg. Pioneer to Universal, Universal to Commodore). If single DIN stereo you'll need a spacer for it.
    You might need to bypass wiring to make the aerial work.
    VX II S-Pack
    Aug 2010
    Victoria, Melbourne
    Hey guys, I got the PIN off the previous owner.. The reason I wanted to take the headunit out was to check the wiring was hooked up for the rear door speakers
    VX lumina
    Jul 2008
    SE Melb
    if you dont have the pin, you can pull the headunit out without unplugging the loom..
    you remove the glvoebox, remove the little kick panel (3 screws around the glove box area and one down near the seat)
    then the headunit wires run through there, cut the cable tie holding the loom in place and remove the headunit.. you should be able to bring the unit about 20-30cm's out of it hole
    VX II S-Pack
    Aug 2010
    Victoria, Melbourne
    VX Commodore S Supercharged
    Sep 2010
    Smile
    Do you have speakers in your rear doors??
    If not, leave the headunit alone and take the rear door panel off and connect up a speaker and turn the radio on - you'll soon see if they are connected.
    2001 Commodore VX-S (Series I)
    12.04.2001 - 29.04.2010
    2002 Commodore VX-S Supercharged (Series II)
    23.05.2010 - Current
  1. vz aftermarket headunit question
    By CoJang in forum Car Audio
    Last Post: 09-03-2010, 10:38 PM
  2. After market headunit question
    By JC229 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 18-11-2009, 07:21 AM
  3. Headunit Question
    By Ozza in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-09-2008, 09:43 PM
  4. VZ Headunit Question
    By Wacky in forum Car Audio
    Last Post: 20-03-2008, 08:38 AM
  5. Quick Question: VT SS RIMS = Quick Answer please
    By Henerz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-03-2006, 06:33 PM
