Hey guys. How do i change the starter in my ute. its a 5.7lt auto. thanks
Get the front up on stands, chock the back wheels and get under the car. undo the battery cable and place it where it can't short or wrap a bit of insulation tape around the end. take the small wire/s off, remember where they go. undo the two bigger bolts holding the starter on and don't let it fall on your head. reverse the procedure to put it back in. Holden reccommends that you remove the battery cable from the positive terminal to prevent air bag deployment. Alright if you don't mind resetting the radio code. Probably safer to do it that way.
