Results 1 to 4 of 4
Thread: Lowering a WH Statesman Series 1
    WH Statesman
    Sep 2010
    Default Lowering a WH Statesman Series 1
    So im looking at buying lower springs for my WH Statesman its a series 1 2000 model. Just wondering if i need to do any other mods to it or whether i can just install the new springs?
    GAMBLR's Avatar
    GAMBLR is offline More trouble than u think
    '04 VZ Calais LS1
    Dec 2006
    Whyalla (yawn), South Australia
    Depending on what height you plan on using. You can get away with Low or Super Low springs without replaching the shocks, but any lower and it's highly advisable to use shortened shocks and struts, which provide better handling and performance. Even at Low or SL height, it helps to have shorter shocks.
    Thats it for lowering, but you may find you need or want more suspension parts later. Camber adjustment to prevent excessive wear of inner edge of rear tyres, sway bar link pin kit which quite often fails on lowered Commodores.
    CruznCalais
    [GAMBLR]
    The VZ is here! About time!
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by Copini_17 View Post
    If you car has Level Ride Suspension you will need to disconnect that.
    MY RIDE
    vx berlina s2
    Oct 2010
    adelaide, south australia
    Quote Originally Posted by GAMBLR View Post
    so if going to superlow you dont have to change shocks but wouldnt hurt ?????
  1. kings, pedders or lovells springs for lowering vs statesman/caprice advice?
    By Caprice5L in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-06-2010, 11:08 PM
  2. Lowering VS statesman
    By west-side in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-05-2010, 08:08 PM
  3. Vs statesman lowering springs questions
    By vsl67 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-06-2009, 09:59 AM
  4. Lowering VX Series 2 - angle problems??
    By DavidPartay in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-08-2006, 08:33 PM
  5. lowering my vs statesman
    By Statesman87 in forum General Discussion
    Last Post: 12-04-2006, 01:04 AM
