Results 1 to 10 of 10
Thread: Airbag light
    VX S pack
    May 2010
    Default Airbag light
    hey um just recently my airbad light has come on when i start my car...... i got my mechanic mate to use the computer thing to cancel the code but the next day it came back on
    does anyone know wat could be the problem and can it be fixed
    cheers
    VXII
    Nov 2009
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Your mechanic should have checked what the code was and that should have directed him to the problem. The light comes on because there is a problem and that should be checked not just clear the code.
    MY RIDE
    madutedude's Avatar
    madutedude is offline MADUTERIS
    vy ss
    Dec 2008
    Boronia
    VX Commodore
    Sep 2010
    VIC melb
    This is the same with my car aswell. dno why it comes on I got it checked out but It came on again. I suggest take it back to your mechanic, thats what I'm doin
    VX Commodore S Supercharged
    Sep 2010
    Mine came on after I had removed the passenger seat to install my Stereo Amp. I managed to catch the seat belt pretensioner cable (part of the Air Bag System) between the Amp and the Seat rail, which shorted and caused the fault. Our mechanic couldn't clear it, so i took it to Holden, who don't repair stuff - they replace it at a cost of $280.
    If I had known or if it , I would take both seats out (don't turn the ignition on), inspected the wiring by hand for nicks/cuts/breaks, re-solder as required and tape (or some heat shrink), be extra, extra careful of the wires running under the seat rails, and then take it to a Mechanic to clear the error.
    2001 Commodore VX-S (Series I)
    12.04.2001 - 29.04.2010
    2002 Commodore VX-S Supercharged (Series II)
    23.05.2010 - Current
    VX S pack
    May 2010
    yeah i might check the wires but i havent touched them at all it just came on after 6 months of owning the car and now sometimes the horn doesnt work so a mate believes it could be some spring behind the airbag but im gonna have to go tothe mechanic and get it check cause it annoys the hell out of me
    thanx for ur help guys
    also does anyone know if my 01 vx s pack auto has traction control
    cheers
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by VX S-speeddemon View Post
    switch
    cheers
    As far as I am aware, if it doesn't have a traction control switch to the right of the gear selector then it doesn't have traction control.
    Clock spring is the thing you were referring to.
    MY RIDE
    VXII
    Nov 2009
    Never repair airbag wiring. It isn't designed to be repaired, and unless you want your head to land in the back seat (separate to your body), don't bring anything near the airbag wiring that could induce current or voltage, that includes static electricity.
    HoldenOnn's Avatar
    HoldenOnn is offline Roll Cage Territory
    VZ Calais Alloytec190
    May 2009
    Busselton, WA
    ......also does anyone know if my 01 vx s pack auto has traction control
    cheers
    Click link below to check the specifications of your model plus many others;
    Unofficial Holden Commodore Archive
  1. ENGINE light, ABS light, TRAC OFF light AIRBAG light and OIL light
    By jamierawr88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-10-2011, 09:06 PM
  2. >Need help< AIRBAG LIGHT
    By DND in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-08-2009, 11:16 AM
  3. SRS airbag light is on!
    By bedo2405 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-05-2009, 10:42 PM
  4. SRS Airbag light
    By The Raz in forum General
    Last Post: 05-03-2009, 11:05 PM
  5. Airbag Light
    By mmazz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-03-2004, 07:27 PM
