Results 1 to 6 of 6
Thread: VT Suspension
    VT Acclaim
    Oct 2008
    Default VT Suspension
    I brought my car second hand and can only assume that bushes, shocks etc havent been touched. Car is nearing 150k and im thinking about getting the suspenion over hauled. I want to lower it slightly as well so I know ill be needed springs, shocks but what else should i look at replacing?
    And can anyone recommend me a place in Melbourne- Eastern Subs?
    ve sv6
    Aug 2010
    possably link pins, lower control arm bushes, front radius rod bushes, rear radius rod bushes and maybe bearing plates and bearings.
    VZ AWD One Tonner
    Jul 2006
    Hi mate,
    Have a squiz here:
    KYB / Kings Commodore Lowering Packages!
    Apart from shocks, the main thing that need replacing are link pin bushes, and front radius rod bushes.
    Regards,
    Greg
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
    jazza15 is offline Jarryd
    1999 VT II S
    Jun 2008
    Eltham North, VIC
    Quote Originally Posted by gslrallysport View Post
    Regards,
    Greg
    I second that. These would be the most likely to be needing replacement if it hasn't been done already. Get a mechanic to have a look at your car first. Pedders will go over it for $14, giving you a full quote on what needs doing, so that you can have a think about it. Post up what needs doing here and I'm sure you will get plenty of opinions, useful or not.
    Jan 2008
    NSW
    go to pedders and get a 28 point safety check. its only $14. they'll tell you what you NEED to replace. If it aint broke, dont fix it coz you could be spending that green on something else.
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Don't go to pedders if you enjoy money in your pocket.
    Mines ticked over 160k and i have done most of what glenn l recommended. and can say i highly recommend his recommendations.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
  1. Air bag suspension for my vs ute
    By ryan86 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-11-2009, 06:25 PM
  2. v8 suspension into a v6 ?
    By muzza in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-07-2009, 03:29 PM
  3. suspension
    By Influx69 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-07-2009, 07:04 PM
  4. Suspension
    By AlX in forum VY Holden Commodore (2002 - 2004)
    Last Post: 14-03-2006, 08:04 AM
  5. VH Suspension
    By mza in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 12-03-2006, 11:45 AM
