Before anyone has a go at me, yes i have done a search on this but im asking a different question although very similar. Im pretty sure i know the answer to this (blown head gasket) just to make sure... So the symptoms started just the other day when my car kept stalling only due to the LPG converter freezing up because there was not enough water in the radiator. So i topped it up which solved that problem and kept a close eye on it. Just today i filled the radiator up again, this time taking 4 litres and within a minute i spot some water leaking from the top-front location on the engine. Blow heady yes?
stuffed water pump/thermostat gasket??
is there water in the oil?
top front? can you be more specific?
but yeah id do an oil change to see if theres any water in it
yeah obviously..
but yeah, you my friend have a blown head gasket
well if there is definetely water/coolant in your oil then its a head gasket issue
as for the front where the water coming out, that could be a different issue ie water pump
proby ur inlet manifold gasket they always let go. i would look at that first before getting carried away with head gasket cause they rarely let go
It's the waterpump. Thank F*ck!!!!
would that explain the water in your oil though
Well to be honest i wasn't too sure i thought the oil seemed a little watery but it was actually fine, just shows how long its been since i've checked my oil :-P
haha lucky![]()
