Hey all...
a question relating to my vt,
it seems to be leaking a little bit of oil around the rocker cover..
does that mean i just need some new sealant around it or is it a more serious problem?
thanks,
kc
New gaskets should fix the problem. They leak as the get old.
MY RIDE
if oil is coming down the front of the motor or the back middle for that matter (under coil packs could be valley gaskets aswell) valleys are very common on vt so are rocker cover gaskets
you COULD just do the easy thing and tighten the bolts until FIRM with kilometers they always comes loose on vt's
db_notso, would it serve any purpose to install shake proof washers under the heads of the rocker cover bolts?
thanks guyswill try this out...
always willing to accept help,
its much appreciated
KC, what was your method to fix this problem?
i think every ecotec leaks from the rocker covers =(
"db_notso, would it serve any purpose to install shake proof washers under the heads of the rocker cover bolts? "
well you are supposed to replace the bolts on the inlet manifold when you do the valleys, but if you clean the old bolts and use loctite/threadlocker to the bolts and tighten them evenly it normally wont leak for a very long time after that...
on the rockers to fit spring washers can be done but is a pain to do as they are semi attached bolts, just do the bolts all up tight and even then wash it off. rockers gaskets are just really common to need to be done on ecotec motors.
okay thats helpfulcause i saw some oil next to the covers, im hoping to replace the gaskets next week, there will be abit done to it
Sorry bpx 31h i havent acctually done anything yet lol,
as its my girlfriends car and i wont see it till the weekend...
ill give tightening up a go and prolly end up replacing gaskets just incase![]()
Okay coolonly my ride side has abit of oil so I'll replace both gaskets
I got both rocker cover gaskets for bout $24 a pair there easy enough to do, think it took bout 10-15min havnt leaked since
where did you get yours from? holden? cause ive seen them on ebay for $30 a pair.
ordered mine should be in on thursdayy
