Results 1 to 17 of 17
Thread: VX Headunit - Trouble installing
    VX Executive
    May 2010
    Mornington Peninsula
    Default VX Headunit - Trouble installing
    Hey guys..
    Short Story:
    Headunit wont work - No power
    Stock HU wont work anymore - power but no writing on the screen
    Long Story:
    Have had a shit amount of unluckiness happen over a stupid stereo.
    Basically i bought a Pioneer HU and tried to install it with harnesses. Everything worked fine except the antenna which i need to hardwire separately. However the rear right speaker didnt work. The guy took the HU into the shop to test it on one of those and the front right didn't work so he blamed the car but still sent the HU off to get fixed because i proved to him the stock stereo worked fine.
    The guy called me a week later and said it might take longer ill give you the newer model instead so i took it. Still back right didnt work so i changed the Harnesses and it did work . But i noticed Supercheap auto had it for 40 less so i refunded it and went to supercheap auto. However there was a JVC one there i liked for 114$ so i bought that and a harness for it. The harness was incompatible so i decided to hardwire it mysellf.
    For the VT:
    Accessory - Yellow
    Batter (constant) - Orange/black
    Ground - Black/white
    Antenna - Yellow/Red
    FL + Tan
    FL - Grey
    FR + LightGreen
    FR - Darkgreen
    RL +Brown/Black
    RL -Yellow/ Blue
    RR + BlueOrange
    RR -Blue/Black
    Because i might use my stock stereo again i decided to keep the VT/VX harness in and just cut off the adapters on those. The JVC HU had two antenna wires (Remote and Automatic) I chose Auto fyi.
    So basicly there is no power getting to this new HU, it just wont turn on or anything. I hardwired so there was no solder and havnt taped it up, as if it didnt work i would have had to untape it all.
    I didnt ground the black, because i didnt think i needed to, and didnt take the negative off my battrey because i didtn know how. Im pretty ignorant.
    So if you guys have any advice or questions feel free to help, would be much apprecaited
    VX Evecutive wagon
    Jun 2010
    Alexandra Hills
    VX Executive
    May 2010
    I would rather learn though so i dont have to keep paying jewish mechanics to do simple things i should be able to do myself
    VT Calais
    Mar 2009
    SA - Victor Harbor
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    how did you "hardwire" it without solder or taping up connections? chances are youve shorted something and blown a fuse or 2.
    check fuses, ground the black wire, make sure none of the wires are bare/touching and try again.
    if you want to learn to do something, learn to do it right. buy a soldering iron, learn to solder, solder the connections properly, tape/heatshrink them up so they dont short or you're just going to be sending headunits in for repair every time.
    VK SL + LH Torana + VZ Crewman
    Sep 2010
    VQ S2 304
    May 2009
    Quote Originally Posted by tdirago View Post
    Hey guys..
    Short Story:
    Long Story:
    For the VT:
    Accessory - Yellow
    FL + Tan
    FL - Grey
    FR + LightGreen
    FR - Darkgreen
    RL +Brown/Black
    RL -Yellow/ Blue
    RR + BlueOrange
    RR -Blue/Black
    Theres your problem
    VX Evecutive wagon
    Jun 2010
    Alexandra Hills
    technicaly speaking it "should" ground through the antenna wire, but just not verry well.....
    if you want to learn to do it yourself maybe go and pay someone to do it for you and ask them if u can watch, or speak to a mate that has done it before,
    if you dont at least tape your conections to try to test it your not gonna get far, i can understand not wanting to solder before testing, but if you dont insulate the wires your risking blowing fuses, or worst case starting a fire and loosing your car all together,
    2004 VY Auto Calais
    Aug 2010
    Hi there, im a mate of Tims.
    Just wired it all up for him, turns out he had blown the fuse by not taping up the connections, also he didn't connect ground or remote. The harness he purchase also had incorrect pins.
    The only issue we are having now is how to get the antenna to go up and down, what wires should i connect for that. Theres only one power wire for the antenna out of the JVC headunit.
    And as far as i know the VX needs two connections for the headunit to go up and down, + and -
    Ohh also as we couldn't find a constant 12v we just connected the Accessory and the 12v to the same cable ( Ignition wire on vx ). So when the cars turned off the headunit loses its memory as its not a constant 12v source. Anybody know which wire on the stock VX is the 12v for power??
    Thanks
    hakhawk's Avatar
    Jan 2005
    hook the blue/white(or is it just blue on the jvc) to the yellow/red on the car. this should make the antenna go up when the unit is turned on, and go down when its turned off.
    constant 12v is orange/black. recheck the fuses, no doubt hes blown that one aswell.
    VX Executive
    May 2010
    ok thanks, yer, i do reckon the constant 12v as blown, however i didnt realise there was a fuse for each of the 14 wires?
    oh and the JVC comes with a blue/white and a blue
    blue/white = remote antenna
    blue = automatic antenna
    the blue didnt seem to wrok so i might have blown that fuse as well? thats only if each wire has fuse, and if not you can see how noob i am at this
    hakhawk's Avatar
    Jan 2005
    not all the wires have a fuse, only the constant and accesories.
    hook the blue up, and it will only wind the antenna up when the radio is selected on the unit, when you change to cd, the antenna will go down. if it has a fuse, it will be on the harness that came with the unit(between the plug and the bare end of the wire) most dont have a fuse.
    VX Executive
    May 2010
    well i've tried blue with blue to no avail.
    However there is an remote antenna output which is bluewhite that i havnt tried, but afraid to because i might blow a fuse.
    hakhawk's Avatar
    Jan 2005
  15. #15
    VX Executive
    May 2010
    The soldering went fine and before i acutally put it in it all worked (speaker wise) but when i got home i realised the back right wasnt working again, and knew it was the harness because the other was faulty as well. So i cut the - and + of the RR speaker off the loom and connected them straight up to the HU ones, and that worked. Then i was looking through the fuses because i thought maybe the speakers had fuses. while there i saw the 15amp Radio fuse, and it was blown so i replaced it and thought maybe thats what stopped the yellow and brown/black from working so i hardwired them and the antenna as well and it all worked out
    so basically i blew the two fuses because i didnt ground and thats why it didnt work for me the first time
  16. #16
    hakhawk's Avatar
    Jan 2005
    no, you blew 2 fuses because you didnt cover the wires and they shorted out, plain and simple. glad you got it working in the end. learn from your mistakes if/when theres a next time.
  17. #17
    vx ss
    Dec 2009
    get a mate to show you how to disconnect the negative battery lead, before messing with any electrics
  1. Im having trouble installing my sub.
    By hobbsy in forum Car Audio
    Last Post: 03-09-2010, 10:50 PM
  2. having trouble taking my headunit out
    By adamrollo9 in forum Car Audio
    Last Post: 26-06-2010, 12:53 PM
  3. Installing headunit in Pulsar for sis.
    By manvr in forum Car Audio
    Last Post: 19-12-2006, 07:20 PM
  4. having trouble with removing headunit
    By Brycestro in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-02-2006, 11:33 PM
  5. Installing a headunit in a vn statesman...
    By katq in forum Car Audio
    Last Post: 22-03-2005, 12:20 AM
