Results 1 to 3 of 3
Thread: VZ steering wheel into a VT/VX?
    Commodore M6
    Jul 2010
    East Coast
    Default VZ steering wheel into a VT/VX?
    http://img408.imageshack.us/img408/1016/img0078qj.jpg
    anyone done this? seems like a nice looking upgrade
    what would you need?
    wheel, airbag and column cover?
    VT Acclaim Wagon
    Oct 2008
    credit to orig 3n on L67Torque.com. Same info in different form in GM manual
    I went into this a few months ago. This is what I found:
    Tools and Parts: 5/8" socket, 1/2 inch drive ratchet, flathead screwdriver, T30 torx bit, spare horn connector.
    1. Disconnect battery
    2. Remove airbag fuse and turn headlight switch on for 10 seconds then off again
    3. Disconnect airbag wiring harness from under dashboard (optional)
    4. Remove the 4 torx screws from the back of the wheel to release the airbag and remove it slowly.
    5. Keep the airbag facing away from you and slide your flathead screwdriver under the yellow airbag connector and pop it out.
    6. Remove the airbag and place it in the open, out of sunlight, face up and away from static sources.
    As you can see both airbags share the same wiring harness
    7. Next you will need to crack the bolt on the steering wheel using the 5/8" socket bit, if it is very tight it might pay to have someone hold it while you work away or step out of the car and pull the wheel and wrench together. I used a torque wrench to get the leverage i needed.
    8. Once the bolt is removed, center the steering wheel, then you will be able to jiggle the wheel off the spline and slide it off slowly. Take care to hold the clock spring in place, but if you loose it, it has directions to align it again anyway.
    9. Grab the new VY-VZ wheel and slide it on as soon as you can straight to lock the clock spring back in place. Ensure the green shows fully in the window of the clock spring and tighten the bolt back down.
    There is a change between the old VT horn system and the new VY one. The VY system uses 2 plates (1 on the back of the airbag and one on the wheel) seperated by springs and there are clips on each plate to connect to. Some VY-VZ wheels will come with the connector wiring to plug into the existing horn connector but mine didn't. All you need to do is get a spare connector with a nice length of wire and put a crimp on the end of each wire to connect to the plates. On the old VT wheel the horn connector just plugged straight into the airbag module...
    10. Once you have made up the horn wiring adapter just connect the red plug to the horn plug on the steering column and plug the 1 crimp into the back of the airbag plate and the other to the steering wheel plate.
    11. Next plug the airbag connector back in to the new airbag and to a final check to make sure the area is clear around the airbag.
    12. Line the airbag locking pins with the holes on the wheel and push down to lock it in place.
    13. Put in the airbag fuse again and reconnect the battery. While standing out of the car put the car on ignition and wait for the airbag light to turn off so you know it has passed the self test.
    14. Start the car up and full lock the wheel to both sides to ensure everything feels right then take it for a test drive
    madutedude's Avatar
    madutedude is offline MADUTERIS
    vy ss
    Dec 2008
    Boronia
    yea man done this its fairly simple just follow the instructions these guys have done up
  1. Boss kits for VT steering wheels to fit a VZ/VY steering wheel?
    By nEb. in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-12-2011, 07:28 PM
  2. [ACT] MOMO steering wheel & no brand steering wheel
    By calais24/7 in forum Parts And Other Items For Sale
    Last Post: 23-02-2010, 05:33 PM
  3. Adjusting the angle steering wheel / steering column
    By Kabooooom in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-02-2010, 05:12 PM
  4. after market steering wheel made steering crap!
    By jet_pilot in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-01-2008, 09:07 PM
  5. Your thoughts on replacing steering wheel with airbag to a MOMO wheel....
    By *VOLATILE* in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-02-2006, 08:36 AM
